Blender's Dynamic paint
- Egert_Kanep
Can we access the data created with dynamic paint. Could be useful for lots of things.
Re: Blender's Dynamic paint
Doesn't it work with
- vertex colors
- vertex displacement
- image sequence
which we all support?
- vertex colors
- image sequence
- Egert_Kanep
Yes, my bad, I just had to send dynamic paint to correct vertex color layer. But for some reason vertex color has same intensity everywhere, but in viewport it has falloff
Can you show the material setup (and/or upload the file)?
- Egert_Kanep
I added little test scene.
- Attachments
- dynamic_paint.blend
- (4.55 MiB) Downloaded 479 times
The same happens in Cycles, so it doesn't seem to be a LuxCore specific problem.
- Egert_Kanep
Yeah, I did a test with cycles also. One thing that works for sure is weights. But there is no way to use them with shaders yet
You could try if image sequence mode has the same problem or not.
By the way, vertex colors are not the best anyway, because in Blender they are stored with 8 bit per channel (like a common LDR image).
