BlendLuxCore Development
Re: BlendLuxCore Development
The amazing shader animation bug is Back :oops:
Frame first
Frame middle
Frame last
the wave should move. Caustics cache isn't persistent.In fact the node is lock to frame value even at the end.
As been solved in 2.9 https://developer.blender.org/T76381
Forget that. Now going to test it.
Sharlybg wrote: Sun Sep 13, 2020 8:24 pm As been solved in 2.9 https://developer.blender.org/T76381
doesn't work. it work only if you manually render frame by frame with F12 not CTRL + F12 :oops:
Blendluxcore don't hide geometry in Edit mode. I mean if you take a mesh and then hide some poly they are still visible in render preview.
Cycles has the same behaviour.
B.Y.O.B. wrote: Tue Sep 15, 2020 11:34 am Cycles has the same behaviour.
Sorry i was talking about the material preview mode.
Sharlybg wrote: Mon Sep 14, 2020 4:47 pm Bug reported again : https://developer.blender.org/T80780
Strangelly it work on blendluxcore 2.4 but not on lastest 2.5 build. look like a Blendluxcore bug :?:
Blendfile
Test blend.blend
(3.13 MiB) Downloaded 684 times
Blender 2.9 + Blendluxcore 2.4 work so it is blendluxcore 2.5 the issue ??
Please Simon we need you here : https://developer.blender.org/T80780
The Dev explicitelly want your help.
