Something happened with Warmup and Test Step Samples in the daily build?
The SAMPLECOUNT pass starts to change only after about 70 samples now, even if I set 1 or 5 for both.
This is unlikely because the samplecount pass shows the effect of adaptivity.FarbigeWelt wrote: Tue Apr 16, 2019 9:38 am What if Sobol acts contrary, I mean adaptive 0.0 in blendluxcore
pushes Sobol to be perfectly adaptive and vice a versa?
- alpistinho
- Developer
Yes the parameter has been changed and blendluxcore has not been changed yet.
You could export the scene, change the parameter and render it on luxcoreui. I will try to update the SDL page today
Note: as an end user, I would wait a few days before trying to test this new stuff, it's not in a usable state yet. As alpistinho said, the Blender addon was not updated to use the new properties yet, for example.
I see, thanks!alpistinho wrote: Tue Apr 16, 2019 5:25 pm Yes the parameter has been changed and blendluxcore has not been changed yet.
Unfortunately I have a constant lack of time. (Work + family)If you can, give Random a try just to confirm my findings.
Would it help you if I uploaded the scene with the lamp shade hidden?
- alpistinho
- Developer
Sure,
Any help is welcome.
But I am almost sure that what is not working is the Sobol sampler, and not the adaptivity
Thanks
Thanks
3d is just a hobby for me, and I try to help you as much as I can.B.Y.O.B. wrote: Tue Apr 16, 2019 5:28 pm Note: as an end user, I would wait a few days before trying to test this new stuff, it's not in a usable state yet. As alpistinho said, the Blender addon was not updated to use the new properties yet, for example.
Here's the file with Null (Transparent) material set to the lamp shade.
- Attachments
- ElskaLamp-adaptivity2.blend
- (4.37 MiB) Downloaded 782 times
Sampler (left - right): Sobol - VS - Random
Adaptive Strength (top - bottom): 0.00, 0.50, 0.95
Device: CPU
Engine: Path
Halt Condition: Samples: 256
Scene posted here (PhotonGI Cache thread)
If there's anything else i can do...
PS
(i'll may be late, am getting eyes examined & will loose sight for some time, week at most)
Device: CPU
Engine: Path
PS
- alpistinho
- Developer
You have wrote that at the time and I understand the rationale that the sobol distribution will only preserve its low discrepancy properties for every pixel if each one has it's own pass variable.Dade wrote: Wed Mar 06, 2019 11:09 pm There is one aspect of Random/Sobol samplers you could look into: the adaptive aspect. For instance, one part to improve is that they are currently skipping samples instead of just progressing slower on some (already converged) pixel. The current advantage is that there is one single global "pass" instead of a "pass" for each pixel. It saves some ram but it is pretty bad for sampling.
We've implemented this and I as far as I've seen until today, the code looks right.
Each pixel is following correctly it's own variable
Running it single threaded makes no difference
But the sampling points are not looking like Sobol when using the adaptivity And it looks much better when the strength is set to zero There's something eluding me here, and it is probably something stupid
