PhotonGI cache
Re: PhotonGI cache
Can you make something like an experiment... hardcode all values and see if and when people actually have issues with this? Maybe expose one single parameter: "precission multiplier" that could multiply numbers + lower lookup? For me after all this time it is super easy to use this cache, but for newbies this will require quite some time to dedicate to learning.
Re: PhotonGI cache
I can also reproduce that the darker output with HDRI + PhotonGI is still there.
Scene attached.
Scene attached.
Re: PhotonGI cache
This is the output of the LIGHTCPU engine:
Re: PhotonGI cache
I remenber Dade said he want to make most of the settings automatic by the ends after we have solid base and bug fixed.lacilaci wrote: Sat Mar 02, 2019 1:44 pm Can you make something like an experiment... hardcode all values and see if and when people actually have issues with this? Maybe expose one single parameter: "precission multiplier" that could multiply numbers + lower lookup? For me after all this time it is super easy to use this cache, but for newbies this will require quite some time to dedicate to learning.
Re: PhotonGI cache
The only good bug, it is a dead one:
P.S. "Starship Troopers" by Robert A. Heinlein.
Re: PhotonGI cache
good stuff, but I see on azure another build already started:
"PhotonGI can now render black rooms"
what is that?
what is that?
Re: PhotonGI cache
You are certainly doing your part about that
Re: PhotonGI cache
This: viewtopic.php?f=4&t=949#p10770lacilaci wrote: Sat Mar 02, 2019 3:11 pm good stuff, but I see on azure another build already started:
what is that?![]()
PhotonGI Metropolis was refusing to render black rooms ... picky damn sampler but it is hard to not agree
