Do I need this one
path.maxdepth = 32
Look like light path value we change inside blender.
Or is something else ?
Post by marcatore »
Dade wrote: Mon Jul 12, 2021 12:11 pm Are you mislead by the number of samples per pixel ? I took the screen shots at random points to show the difference in samples/sec and not in noise.
First was taken with 31 samples per pixel while the last was taken with 207 samples per pixel (clearly the last has less noise even with fast RR settings).
Clear... sorry. You're right.
Neverming... I was just dreaming looking at that image :)
JulianoLisboa
Post by JulianoLisboa »
Dade wrote: Mon Jul 12, 2021 12:07 pm
Sharlybg wrote: Mon Jul 12, 2021 9:24 am
Dade wrote: Sat Jul 10, 2021 11:04 am
There are more settings:
# Higher is the max. depth and more effect RR settings will have
path.maxdepth = 32
# At what depth, RR will start to operate: lower is faster. Range [0, path.maxdepth]
path.russianroulette.depth = 3
# At what value, RR will start to operate: lower is faster. Range [0.0, 1.0]
path.russianroulette.cap = 0.5
Please Dade can i have all the settings for the super fast RR ? the one that produce this image :
This (faster):
path.maxdepth = 32
path.russianroulette.depth = 1
path.russianroulette.cap = 0.0
Vs. (slower):
path.maxdepth = 32
path.russianroulette.depth = 32
path.russianroulette.cap = 1.0
This doesn't work in Blendluxcore correct?
In Blendluxcore it should be like this i think :
path.maxdepth : 32,
path.russianroulette.depth : 32,
path.russianroulette.cap : 1.0,
JulianoLisboa
Sharlybg wrote: Mon Jul 12, 2021 2:08 pm In Blendluxcore it should be like this i think :
path.maxdepth : 32,
I don't know how to do it, is it by command line?
You put them in this file at this location: https://github.com/LuxCoreRender/BlendL ... fig.py#L63
B.Y.O.B. wrote: Mon Jul 12, 2021 8:15 pm You put them in this file at this location: https://github.com/LuxCoreRender/BlendL ... fig.py#L63
the python file to be modified is in your blendluxcore installation folder inside blender script appdata roaming blabla it is the config.py inside the export folder of blendluxcore.
And you will end with that:
definitions.update({
            "path.maxdepth" : 32,
            "path.russianroulette.depth" : 32,
            "path.russianroulette.cap" : 1.0,
            "renderengine.type": luxcore_engine,
            "sampler.type": sampler,
            "film.width": width,
            "film.height": height,
            "film.filter.type": filter_type,
            "film.filter.width": config.filter_width,
            "lightstrategy.type": light_strategy,
            "scene.epsilon.min": config.min_epsilon,
            "scene.epsilon.max": config.max_epsilon,
            "path.albedospecular.type": scene.luxcore.denoiser.albedo_specular_passthrough_mode,
            "path.albedospecular.glossinessthreshold": 0.05,
Or take this python file modified of the original config.py inside blendluxore folder :
config.zip
(5.19 KiB) Downloaded 670 times
Are you aware you are using the slowest possible settings (not the fastest) ? And it was a proof of concept: a depth of 32 is quite extreme.
P.S. don't use path.maxdepth, it is already exposed in BlendLuxCore (and you are overwriting the BlendLuxCore setting or BlendLuxCore is overwriting your; It depends on the order of definitions).
bestman8
Post by bestman8 »
how hard would it be to have that setting in the ui like under advanced
