Shadow Terminator problem
Re: Shadow Terminator problem
Post by Racleborg »
by Dade » Sat Aug 10, 2019 3:32 pm
Racleborg wrote: ↑
Fri Aug 09, 2019 6:21 pm
I am not sure if this is relevant to the currently discussed Bump issue, but I don't appear to be getting any Bump effect be with the Checkerboard Texture like it does with other textures such as Distorted Noise?
This should be normal: the bump is proportional to the difference of 2 adjacent pixels, if the pixels have the same color (like inside a check), there is no difference and the normal is unmodified. So it is modified only on the sharp edge between 2 checks.
Thank you for the explanation
demonstration of the problem on a simple plane and weak bump
bump
no bump
file
bump.blend
(532.22 KiB) Downloaded 452 times
provisory wrote: Sun Aug 11, 2019 9:27 am After some comparisons I think again, that something is not perfect with LuxCore bump mapping.
Left side is highly subdivided and has displacement modifier with the bump texture.
Right side is low poly and has bump mapping with the same bump texture.
Cycles:
LuxCore after shadow terminator taming:
LuxCore before it:
I should have fixed the problem, this is a rendering before the fix:
and this after the fix:
Extreme bump scale values are now handled far better, this was before:
Dade wrote: Tue Aug 20, 2019 9:02 am
Cycles:
LuxCore before it:
This looks fantastic, how about long flat planes with bump, won't they look like they collect dust?
will give this a go as soon as it's "cooked"
lacilaci wrote: Tue Aug 20, 2019 9:07 am This looks fantastic, how about long flat planes with bump, won't they look like they collect dust?
Your test scene seems to work fine with the new version:
Dade wrote: Tue Aug 20, 2019 9:12 am
Amazing, thanks!
provisory
Post by provisory »
Dade wrote: Tue Aug 20, 2019 9:02 am I should have fixed the problem...
Looks good, thank you!
(I'm away from my computer for a few days. I'll test it when I'm back.)
tokiop
Post by tokiop »
Nice result and collaboration, thanks both for your investment !
Just to confirm, both shadow terminator fix and bump mapping is now working excelently and in 2.81 daily build! Perfect!
provisory
Post by provisory »
I made some tests, and I also think it works nicely.
...except the problem with the translucent materials:
http://forums.luxcorerender.org/viewtop ... f=4&t=1325
