Where can I find it? I only see Scene::GetLightCount().
big mirrors and fireflies
Re: big mirrors and fireflies
This: https://github.com/LuxCoreRender/LuxCor ... f0491b70e9
Downloaded latest build and it works fine...
I'm experimenting with the visibility options to check the best setup.
In your tests, did you disabled all the vibility options? At the moment I've tried just the specular one and it's perfect in the mirrors.
I did but like you said it can be limited to specular only in this case.marcatore wrote: Thu Aug 01, 2019 7:51 am In your tests, did you disabled all the vibility options? At the moment I've tried just the specular one and it's perfect in the mirrors.
Is it possible to add to the 2.8 addon?B.Y.O.B. wrote: Wed Jul 31, 2019 1:11 pm I have exposed the setting.
https://github.com/LuxCoreRender/BlendL ... 1906d8f090
I've opened an issue so you have a notice for this.
Thank you in advance.
(I've tried to do by myself with no luck... I can show the options in the UI but they don't work and I have errors in console...so I'll have to wait
