Denoiser Integration
Dez!
Re: Denoiser Integration
Post by Dez! »
In anticipation of noise reduction I stopped all 3D projects. I switched to web design. In my scenes there is a lot of work for noise reduction
The firefly removal of the denoiser can work pretty well, but only until too many samples have picked up the same "firefly" (which is technically no longer a firefly in this case, just an unconverged caustic).
edit: However, it seems to kill the glossy reflections. Strange.
no clamping, about 400 samples
Dez!
Post by Dez! »
Can a denoiser handle the channels of light groups?
Yes, but it would need to be run on each lightgroup imagepipeline separately, so it would take a lot more time than if we only denoise the "main imagepipeline".
Dez!
Post by Dez! »
OK. This is really needed option. Without it, the compositing is not possible.
I propose to make such a check
I'm starting a series of 200 renders of LED strips. With noise reduction of all channels, I need to perform 50 renderings, and a bit of compositing. Without noise reduction of all channels, I need to perform all 200 renderings.
andreymd87
Post by andreymd87 »
Dade wrote: Thu May 10, 2018 9:17 am Did I ever said how damn well this thing works ? :lol:
A 10 mins rendering, it makes animations possible.
wow!! what are your denoiser settings?
andreymd87 wrote: Mon Jun 04, 2018 7:11 pm wow!! what are your denoiser settings?
Just the default settings.
andreymd87
strange. i used same default settings but here are some artifacts :(
andreymd87 wrote: Mon Jun 04, 2018 10:57 pm strange. i used same default settings but here are some artifacts :( untitled.png
Try to increase the "Histogram distance threshold" parameter, the result should be smoother.
