Yes, there seems to be a little discrepancy.
Can you make a bug report on github so I don't forget?
Just include the images and the test scene.
first steps on luxcore
Re: first steps on luxcore
The Cycles motion blur looks very wrong, are you sure it isn't using a some fake approximation ?Sharlybg wrote: Tue Feb 13, 2018 1:45 pm 10sc each render on the same cpu/ no clamp for both/ shutter at 45 for both:
Done thanks youB.Y.O.B. wrote: Tue Feb 13, 2018 2:35 pm Yes, there seems to be a little discrepancy.
here is the cycles Motion blur panel. but don't really know how they have implemented this inside the core.
but they recently get a huge boost in DOF AND MB: here you have more info about :
https://cloud.blender.org/blog/cycles-t ... 10x-faster
Like I said the Cycles motion blur look wrong, there is barely any highlight motion blur. Are you using a not linear shutter curve ?Sharlybg wrote: Tue Feb 13, 2018 3:10 pm here is the cycles Motion blur panel. but don't really know how they have implemented this inside the core.
no shutter curve like in the panel i've uploadedAre you using a not linear shutter curve ?
I've maybe found a bug here : my lake shader don't want to render in viewport (giving a matrix invert error output) and appear matte at final render. Blend attached :
https://drive.google.com/open?id=1CFVz- ... rt7gN2yN25
The Z scale of object "Plane.027" is set to 0.
If you change it to 1, it exports correctly.
Not sure how we should handle cases like this.
- We could add a small epsilon to all values of the transformation matrix if determinant == 0 (when the matrix is non-invertible)
- Or we could provide a better warning/error message
The first option is more user friendly !
Well, I kind of implemented both now.
You get a warning, but the object is exported regardless.
Luxcore Vs Cycles:
Both render under 1mn. same lighting condition. you will also notice that luxcore become darker and noisy when smoke volume is rendered while the lighting stay unchanged.
smoke off :
Luxcore Cycles
smoke on :
Luxcore Luxcore BiDir
Cycles
smoke off :
Luxcore Cycles
smoke on :
Cycles
