Windows: Can't enable addon in latest Blender
Re: Windows: Can't enable addon in latest Blender
Any error messages in the terminal?
Window -> Toggle System Console.
Hi all,
I've removed all programm data and files and started from a claen system (regarding blender and luxcore).
I've downloaded the blender 2.79a RC1 from the ftp link posted on luxcore website.
I've downloaded latest alpha2 of luxcore with OCL.
After unpacking blender zip file and running it directly without setup, I've tried to install the add on.
Reading the zip file seems to be succesful, but add on activation failed.
I think it's the same error that was initiating this post, but I don't see a solution since I did all the cleaning before.
Thanks for your help.
BR
BR
OS - Windows 7 X64
CPU - Intel CORE i7
CPU - Intel CORE i7
Have you removed also your user settings save in the path shown in the screenshotlighting_freak wrote: Sat Feb 03, 2018 11:59 am I've removed all programm data and files and started from a claen system (regarding blender and luxcore).
I've removed this folder "C:\Users\Martin\AppData\Roaming\Blender Foundation" completly.
Are there any other places blender saves it's user data on windows systems?
BTW, I've just tried to setup the official blender 2.79. Same error appears.
OS - Windows 7 X64
CPU - Intel CORE i7
CPU - Intel CORE i7
It looks like a problem importing pyluxcore module (even if I have no idea of what the German message means). There may be few reason why it fails. Can you try to download the stand alone version of LuxCoreRender and check if the LuxCoreUI runslighting_freak wrote: Sat Feb 03, 2018 12:41 pm I've removed this folder "C:\Users\Martin\AppData\Roaming\Blender Foundation" completly.
You may want to run LuxCoreUI.exe from command line to check if there is a error message.
The german message is "ImportError: DLL load failed: The specified procedure could not be found." in english.
In the past pylux requried some Visual C++ Redistributable, do we still need that for pyluxcore?
Yes, they are required by all VisualC+++ applications: https://www.microsoft.com/en-US/downloa ... x?id=40784B.Y.O.B. wrote: Sat Feb 03, 2018 1:13 pm The german message is "ImportError: DLL load failed: The specified procedure could not be found." in english.
just downloaded the vcredist that you've recommended.
The setup say that it is already installed, so I've used the repair function but that doesn't show any effect.
Additionally I've downloaded the standalone version - the luxcoreui.exe starts without any errors. Unfortunatly I've no scene to test further functionalities. I don't know whether this information is already helpful for you.
Before "alpha 2.0" release I was able to activate the add-on.
I had some other troubles that suggested the complete removement.
viewtopic.php?f=4&t=68#p890
Might be that there is something missing in the alpha 2.0 that was there before?
EDIT:
Is there a source for downloading the "old" BlendLuxCore versions?
BR
EDIT:
BR
OS - Windows 7 X64
CPU - Intel CORE i7
CPU - Intel CORE i7
Hello,
I found a solution that is working for me.
The issue with those warning messages seems to be resolved as well:
That is my approach unsing those data inputs: Running Blender 2.79a from unzipped folder (so without setup)
Install the add-on (alpha 3) and don't activate it. Save settings and exit Blender.
Now unzip the "Standalone LuxCore" version and copy the unzipped files in this folder:
C:\Users\Your_User_Name\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\bin
After this starting blender again and activate the LuxCore add-on.
Working! Happy!
So I think there are some file not up-to-date or not available in current BlendLuxCore package. It might be not recognizable if you had previous versions on your system before, but on a clean one the decribed setup process fails. Please have a look in the download packages again.
BR
Working! Happy!
BR
OS - Windows 7 X64
CPU - Intel CORE i7
CPU - Intel CORE i7
Weird, I did a fresh install of the win64-opencl zip of BlendLuxCore on my Windows yesterday and it works out of the box.lighting_freak wrote: Sun Feb 04, 2018 12:42 pm So I think there are some file not up-to-date or not available in current BlendLuxCore package. It might be not recognizable if you had previous versions on your system before, but on a clean one the decribed setup process fails. Please have a look in the download packages again.
I see that tbbmalloc.dll was added which is not included in BlendLuxCore/bin, maybe that's the problem. I'll add it to the package script and re-upload the Windows zips.
edit: done. Can you check again if it works now when you only download the BlendLuxCore zip?
