The flickerfree animation challenge
Re: The flickerfree animation challenge
Dade wrote: Sun May 10, 2020 11:08 am
mischterlampe wrote: Sun May 10, 2020 10:57 am Sorry, but I don't get it. Please exlude the light tracing issue here (I disabled it for this test) and just focus on the indirect cache.
This means, if I rise the threshold, more and more materials should become black. But noting happens. If I rise the threshold to 0.9, which means almost every material should be not in the cache, doesn't exclude the materials, the debug image looks the same like the threshold of 0.05. I lowered the threshold to 0.001, but the result was the same. So changing the threshold of the indirect cache doesn't do anything.
Have you disabled persistent cache ? Otherwise the cache is not re-computed.
Oh, I see, BlendLuxCore is using an hold properties name "path.photongi.indirect.glossinessusagethreshold" while the correct name is "path.photongi.glossinessusagethreshold" because the threshold is used for caustic cache too in PGI, not only for indirect cache.
mischterlampe
Post by mischterlampe »
First problem solved :-)
Dade wrote: Sun May 10, 2020 11:19 am Oh, I see, BlendLuxCore is using an hold properties name "path.photongi.indirect.glossinessusagethreshold" while the correct name is "path.photongi.glossinessusagethreshold" because the threshold is used for caustic cache too in PGI, not only for indirect cache.
I fixed this in the addon.
Fox
Post by Fox »
mischterlampe wrote: Thu May 07, 2020 10:54 am Nonetheless, the caustics of the glass bottle are very weak
The sun is at scale 4. With scale 1 and clamping off, caustics are stronger.
This is Ryzen 3900x equivalent to 1 hour
Border render
Can you try to render the animation with the latest built (when it is ready, in a couple of hours) and disabling the HDR light source (i.e. with only the sun light source) ?
I may have spotted the chain of events that is the source of the problem.
I have now rendered the scene with latest build and HDRI, sky or no background: everything flickers.
But worse is the speed loss: feels like 10 times slower and therefore looks noisier.
Instead I have another suggestion.
Dade wrote: Sun May 10, 2020 10:59 am Knowing the average luminance of the image to render is the only Metropolis requirement but it is not a trivial one: it must be know before doing the rendering (i.e. requires the crystal ball). If the estimation is wrong the result will be brighter/darker than the correct solution.
Why not introduce a manual setting for the average luminance?
By default it should be on auto, like the previous version after issue#312 fix which was rather stable with good light, only not in difficult circumstances like Danish Mood with HDRI.
But there would be an advanced setting similar to how clamping is implemented: the auto setting is already shown as a suggestion.
This would make animations possible even with moving glass bodies, as long as the lights are not animated.
Also we could use a BiDir render to gauge the correct brightness (somehow light tracing never matched BiDir results).
And no further development time would be wasted on this topic, the old speed advantage would be back too.
Of course this would also mean adjustable caustic brightness which is biased, but so what?
BTW here is a render with LuxCore v2.2, somehow nearly no flicker:
DnMd.mov
(617.7 KiB) Downloaded 620 times
mischterlampe
I also rendered with the latest version 41da08d
and I get flickering, too.
https://streamable.com/wsu0yd
World Setting has no light, just one sun, 4k samples.
epilectrolytics wrote: Mon May 11, 2020 8:08 pm I have now rendered the scene with latest build and HDRI
I asked to render without HDR :?:
epilectrolytics wrote: Mon May 11, 2020 8:08 pm Why not introduce a manual setting for the average luminance?
Eh ? Do you know in advance the luminance of an image yet to render ?
Dade wrote: Mon May 11, 2020 8:25 pm
Please quote correctly:
epilectrolytics wrote: Mon May 11, 2020 8:08 pm I have now rendered the scene with latest build and HDRI, sky or no background
So I rendered it three times, including sun only, from which the GIF is made.
After rendering first with auto setting the calculated luminance would be saved and shown in the UI (similar to suggested clamping value in BlendLuxCore).
If it looks ok I switch to manual and use the saved value persistently for all further renderings such as of an animation.
epilectrolytics wrote: Mon May 11, 2020 8:46 pm After rendering first with auto setting the calculated luminance would be saved and shown in the UI (similar to suggested clamping value in BlendLuxCore).
Luminance is not constant across different frames.
