Windows Build FAILED
Re: Windows Build FAILED
kintuX wrote: Sat Apr 25, 2020 11:31 pm PS
Also note: OCL too, takes foooreeveeer to compile now :shock: :P
But now you need to compile only once than is always cached (both for OpenCL and CUDA).
Still I cannot select devices in LuxCoreUI, same error as in BlendLuxCore:
Dade wrote: Sun Apr 26, 2020 12:03 am
Yes, I am aware of that... I just need to get used to it. :) None the less, great work, so thanks again.
epilectrolytics wrote: Sun Apr 26, 2020 7:58 am Still I cannot select devices in LuxCoreUI, same error as in BlendLuxCore:
Did you modify the .cfg file as mentioned?
kintuX wrote: Sun Apr 26, 2020 9:33 am Did you modify the .cfg file as mentioned?
That doesn't change anything, the Cornell file works the same with modification, once I try to change devices via UI editor there is an exit.
Cuda clearly works, sorting out devices not (yet) ;)
I should have fixed this problem, this is likely to have fixed BlendLuxCore problem too.
Dade wrote: Sun Apr 26, 2020 11:07 am
Sadly no, BlendLuxCore still gives an error.
  File "C:\Users\309\AppData\Roaming\Blender Foundation\Blender\2.81\scripts\addons\BlendLuxCore\engine\base.py", line 83, in render_final
    final.render(self, depsgraph)
  File "C:\Users\309\AppData\Roaming\Blender Foundation\Blender\2.81\scripts\addons\BlendLuxCore\engine\final.py", line 49, in render
    _render_layer(engine, depsgraph, statistics, layer)
  File "C:\Users\309\AppData\Roaming\Blender Foundation\Blender\2.81\scripts\addons\BlendLuxCore\engine\final.py", line 61, in _render_layer
    engine.session = engine.exporter.create_session(depsgraph, engine=engine, view_layer=view_layer)
  File "C:\Users\309\AppData\Roaming\Blender Foundation\Blender\2.81\scripts\addons\BlendLuxCore\export\__init__.py", line 251, in create_session
    return pyluxcore.RenderSession(renderconfig)
RuntimeError: Hardware device selection string has the wrong length, must be 4 instead of 2
ERROR: Hardware device selection string has the wrong length, must be 4 instead of 2
IDK, but I think something else also needs to be done on the plugin side to show options for CUDA device/ rendering.
Dade wrote: Sun Apr 26, 2020 11:07 am I should have fixed this problem, this is likely to have fixed BlendLuxCore problem too.
In LuxCoreUI now everything works fine, two GPUs are listed as 4 devices, 2 x OCL + 2 x CUDA and can be selected and applied.
In BlendLuxCore I still get the same error that kintuX has posted above.
In BlendLuxCore, I use pyluxcore.GetOpenCLDeviceList(): https://github.com/LuxCoreRender/BlendL ... ncl.py#L77
Maybe only the GetOpenCLDeviceDescs() function was fixed?
This is the output of List() and Descs() compared:
[('GeForce RTX 2080', 'OPENCL_GPU', 46, 1, 8589934592, 2147483648)]
>>> print(pyluxcore.GetOpenCLDeviceDescs())
opencl.device.0.platform.name = "NVIDIA Corporation
opencl.device.0.platform.version = "OpenCL 1.2 CUDA 11.0.126
opencl.device.0.name = "GeForce RTX 2080"
opencl.device.0.type = "OPENCL_GPU"
opencl.device.0.units = 46
opencl.device.0.clock = 1815
opencl.device.0.nativevectorwidthfloat = 1
opencl.device.0.maxmemory = 8589934592
opencl.device.0.maxmemoryallocsize = 2147483648
opencl.device.0.localmemory = 49152
opencl.device.0.constmemory = 65536
opencl.device.1.platform.name = "NVIDIA"
opencl.device.1.platform.version = "UNKNOWN"
opencl.device.1.name = "GeForce RTX 2080"
opencl.device.1.type = "CUDA_GPU"
opencl.device.1.units = 64
opencl.device.1.clock = 0
opencl.device.1.nativevectorwidthfloat = 1
opencl.device.1.maxmemory = 8589934592
opencl.device.1.maxmemoryallocsize = 18446744073709551615
opencl.device.1.localmemory = 0
opencl.device.1.constmemory = 0
B.Y.O.B. wrote: Sun Apr 26, 2020 3:57 pm I guess this needs an update? https://github.com/LuxCoreRender/LuxCor ... e.cpp#L121
It is a deprecated method: https://github.com/LuxCoreRender/LuxCor ... .cpp#L1752
I guess it is stil used in BlendLuxCore so I updated the code to support CUDA devices too but you should use the "GetOpenCLDeviceDescs()" in the future: https://github.com/LuxCoreRender/LuxCor ... .cpp#L1750
