BlendLuxCore Development
Re: BlendLuxCore Development
Guess what I'm working on
The next release of BlendLuxCore will contain an update button again: https://wiki.luxcorerender.org/BlendLux ... stallation
However, it is even better now. It does no longer force you to update to the latest version, it also lets you downgrade to previous versions.
So far I have only tested it on Linux. I hope it works on Windows.
That is advance feature
Great idea. I can test it on windows on Sunday.B.Y.O.B. wrote: Thu Mar 22, 2018 10:53 pm The next release of BlendLuxCore will contain an update button again: https://wiki.luxcorerender.org/BlendLux ... stallation
I just tested it and of course it doesn't work. Same problem as with the "remove" button.
Maybe we have to import pyluxcore differently, or unload it before replacing it, because it seems like we can't touch the binaries on disk once they are in use.
Related: https://stackoverflow.com/questions/464 ... -pyd-files
- Attachments
- 1517969336648.jpg (8.71 KiB) Viewed 13978 times
You could move it at the next start:B.Y.O.B. wrote: Fri Mar 23, 2018 8:15 amI just tested it and of course it doesn't work. Same problem as with the "remove" button.
1) download pyluxcore.pyd in bin/pyluxcore.pyd.new;
2) ask to restart blender to the user
3) before the "import pyluxcore" check if bin/pyluxcore.pyd.new exist and move to bin/pyluxcore.pyd
4) import pyluxcore
I'll first try to rename the .pyd/.dll files individually, as suggested in the links I found (see the issue).
If that does not work I will try what you suggested.
Hi all,
After seeing the lightgroups video, I think it would be good to have an apply button, that changes all related lights or materials to what lightgroup have and reset lightgroup properties to default ones.
What do you think?
Regards.
What do you think?
Regards.
Asticles wrote: Fri Mar 23, 2018 3:29 pm After seeing the lightgroups video, I think it would be good to have an apply button, that changes all related lights or materials to what lightgroup have and reset lightgroup properties to default ones.
What do you think?
I could add that.
However I was also thinking of this: https://github.com/LuxCoreRender/BlendL ... issues/101
But the two behaviours are a bit orthogonal, so we can implement both.
I logged it: https://github.com/LuxCoreRender/BlendL ... issues/102
The updater now works on Windows, too.
Beware: if you use it to downgrade to alpha7 or alpha6, you won't be able to use it to upgrade anymore
(Lower versions are not available because they have a different naming scheme)
