LuxCoreRender v2.1alpha4 released
Re: LuxCoreRender v2.1alpha4 released
Dez! wrote: Fri Sep 28, 2018 2:03 pm Thank you. disabling bloom, I got the Alpha 4 job.
but I need bloom.
Try to disable film OpenCL image pipeline and just switch film CPU image pipeline (I think B.Y.O.B. has added the support for this option to BlendLuxCore). It should work around the problem.
Dez! wrote: Fri Sep 28, 2018 2:03 pm problem with the denoise remained. he kills the gloss.
Tomorrow, I will check this problem.
Dez!
Post by Dez! »
Thanks. very await the
Dade wrote: Fri Sep 28, 2018 4:19 pm Try to disable film OpenCL image pipeline and just switch film CPU image pipeline (I think B.Y.O.B. has added the support for this option to BlendLuxCore).
Yes, the option is in the imagepipeline settings (camera properties), next to the transparent film option.
Dez!
Post by Dez! »
Yes Alpha 4 to work. and the effect glow is working.
I fixed the OpenCL Bloom plugin problem but I'm unable to reproduce the denoiser related problem. It is working fine here:
Do you get different results ? Is it a Windows only problem ?
Try this scene: viewtopic.php?f=4&t=385#p4495
On my Linux, it shows the problem.
Dez!
Post by Dez! »
I understand the answer correctly?
you can animation from the blender to export to the Standalone version of Luxrender.
and there are no problems with the denoiser in it.
Dez!
Post by Dez! »
I found out why buggy denoise.
Denoise kills the gloss if the scene has Hemi Light HDR
If you only cover the scene with the World HDR, then the denoise works correctly.
Dez!
Post by Dez! »
after joyful jumped 5 minutes I continued to explore the problem
it turns out, it's not in Hemi
it turns out, the fact is that there is no World HDR in the scene. And there are only Hemi.
If the scene is lit World HDR, everything is fine
Post by marcatore »
I have a problem with glossy material.
It seems that the reflections doesn't work. Anyone else?
