first steps on luxcore
Re: first steps on luxcore
Sharlybg wrote: Sun Feb 04, 2018 5:05 pm turn arround suzane and tell me if all is correct. look the eye from the side and back/top.
The suzanne model is non-manifold, which makes it unsuited for anything with transparent/translucent materials.
It is expected to look wrong with volumes, glass etc.
Sharlybg wrote: Sun Feb 04, 2018 4:51 pm This also wan't render :
Thanks for the simpler scene.
The error seems to happen when using a mix material and a volume on a material output.
Have to debug further.
Sharlybg wrote: Sat Feb 03, 2018 10:07 pm test name bug.blend
I fixed the bug.
I fixed the bug.
Bravo. ;)
I've the felling that volume is not working as expected :
https://drive.google.com/open?id=1n7vqD ... rrK6oLVcfY
Can you explain what you are trying to do?
It looks like you have 4 Volumes in the scene. The world, cube and camera are all using a different volume each.
something like this (simulating ambient fog around the sphere) :
http://forums.luxcorerender.org/downloa ... &mode=view
just make an error on the cube volume: it should be cubeV(volume). but the result is not right :?
I think you can just assign one volume to the world, that's enough.
The world volume should be a homogeneous volume with multiscattering disabled and scattering scale around 0.1 for fog.
You can delete the cube I think.
And camera can be switched to auto-detect volume.
Cycles motion blur vs Luxcore motion blur
10sc each render on the same cpu/ no clamp for both/ shutter at 45 for both:
luxcore
cycles
blend
mustang fire.blend
(4.64 MiB) Downloaded 454 times
You have to raise the amount of steps (camera settings, below shutter).
This kind of movement can not be interpolated correctly with only 2 steps.
This is with 20 steps (maybe you need less/more):
nice thanks for the tips. do you also think it is possible to mimic the same result ? also why our Motion blur is so noisy ?
luxcore
cycles
EDIT
I'm also experimenting a slow down in render due to noisy deph of field.
