New OpenCL textures and materials evaluation code
Re: New OpenCL textures and materials evaluation code
By the way, since ray epsilon is still a kernel parameter, I guess I have to pass the default min/max epsilon in BlendLuxCore to KernelCacheFill()?
Only if your default is different than LuxCore default one.B.Y.O.B. wrote: Fri Feb 21, 2020 7:02 pm By the way, since ray epsilon is still a kernel parameter, I guess I have to pass the default min/max epsilon in BlendLuxCore to KernelCacheFill()?
Thank you but I think that I'll wait for a daily BlendLuxCore build. Will it be available more or less soon or we'll have to wait the final 2.3 to switch the daily build to the 2.4?Dade wrote: Fri Feb 21, 2020 6:54 pmThe binaries for all OS can be downloaded from here: https://dev.azure.com/LuxCoreRender/Lux ... dArtifacts (the down arrow on right)
You can replace your pyluxcore.pyd with the one inside the downloaded win64.zip (yes, it is tricky and suggested only for advanced user).
We have to wait.marcatore wrote: Fri Feb 21, 2020 8:45 pm Thank you but I think that I'll wait for a daily BlendLuxCore build. Will it be available more or less soon or we'll have to wait the final 2.3 to switch the daily build to the 2.4?
It would be good to have a LuxCore function that can tell me if a kernel recompilation is necessary, so I can show the UI message about it.
A callback during the rendering if a kernel is compiled or before starting the rendering ? (The later is not possible without having the scene).B.Y.O.B. wrote: Wed Apr 08, 2020 9:22 am It would be good to have a LuxCore function that can tell me if a kernel recompilation is necessary, so I can show the UI message about it.
Are you already intercepting the log output to show some message in Blender ? Could some specific log message do the trick ?
Can it be checked if I have a luxcore scene and renderconfig, but without a rendersession?
renderconfig = pyluxcore.RenderConfig(config_props, luxcore_scene)
# Here I would need the check
# Locks up Blender, potentially compiles kernels
session = pyluxcore.RenderSession(renderconfig)Re: New OpenCL textures and materials evaluation code
It could be RenderConfig methodsB.Y.O.B. wrote: Wed Apr 08, 2020 10:53 am Can it be checked if I have a luxcore scene and renderconfig, but without a rendersession?Code: Select all
renderconfig = pyluxcore.RenderConfig(config_props, luxcore_scene) # Here I would need the check ... # Locks up Blender, potentially compiles kernels session = pyluxcore.RenderSession(renderconfig)
It will be a bit tricky because I compile many kernels but the only one that matter is the big RT/TILE/PATHOCL one. It could be something generic like RenderConfig::HasCachedKernels().
Yes, it should only check for kernels that take long to compile.
Otherwise the UI message can be misleading, because the render session creation also does other stuff that potentially takes a long time, like cache computation.
I have added a new LuxCore API RenderConfig::HasCachedKernels() method to check if a (long) kernel compilation time is required.
