It does but it his linked against LuxCore library and LuxCore library is linked against Intel Oidn so you may be looking in the wrong link step.u3dreal wrote: Thu Dec 05, 2019 1:58 am OK now i'm confused ... does pyluxcore need to be linked against OpenImageDenoise ??? I guess not since it works without![]()
Compile on MacOS 10.13
Re: Compile on MacOS
Oh i should n't assume things i don't know
But files get copied now .... only OIDN lib is still with it's real path on otool -L of pyluxconsole .
Alll other are @rpath ... i really wonder where that happens ??? and where does it happen for lucoreui ?
not link library but link directory
portfolio http://q3de.com/
strange it works for OIIO but not for OIDN ...
same for pyluxcore,so and luxcoreconsole
Where the hell does this @rpath thing happen in the makefiles ????
otool -L luxcoreui
luxcoreui:
@rpath/libomp.dylib (compatibility version 5.0.0, current version 5.0.0)
/System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa (compatibility version 1.0.0, current version 23.0.0)
/System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL (compatibility version 1.0.0, current version 1.0.0)
/System/Library/Frameworks/IOKit.framework/Versions/A/IOKit (compatibility version 1.0.0, current version 275.0.0)
/System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation (compatibility version 150.0.0, current version 1560.12.0)
/System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo (compatibility version 1.2.0, current version 1.5.0)
@rpath/libembree3.3.dylib (compatibility version 3.0.0, current version 3.0.0)
/Users/drquader/Documents/GitHub/macos/MacOSCompileDeps/macos/lib/libOpenImageDenoise.0.dylib (compatibility version 0.0.0, current version 1.1.0)
@rpath/libtbb.dylib (compatibility version 0.0.0, current version 0.0.0)
/usr/lib/libz.1.dylib (compatibility version 1.0.0, current version 1.2.11)
/System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL (compatibility version 1.0.0, current version 1.0.0)
@rpath/libOpenImageIO.1.8.dylib (compatibility version 1.8.0, current version 1.8.11)
/usr/lib/libc++.1.dylib (compatibility version 1.0.0, current version 400.9.4)
/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 1252.200.5)
/System/Library/Frameworks/AppKit.framework/Versions/C/AppKit (compatibility version 45.0.0, current version 1671.10.106)
/System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics (compatibility version 64.0.0, current version 1247.4.1)
/System/Library/Frameworks/Foundation.framework/Versions/C/Foundation (compatibility version 300.0.0, current version 1560.12.0)
/usr/lib/libobjc.A.dylib (compatibility version 1.0.0, current version 228.0.0)Code: Select all
otool -L lib/pyluxcore.so
lib/pyluxcore.so:
/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 1252.200.5)check out my newest stuff http://q3de.com/research/
May be, it is here: https://github.com/LuxCoreRender/LuxCor ... cmake#L199u3dreal wrote: Thu Dec 05, 2019 6:08 pm Where the hell does this @rpath thing happen in the makefiles ????
Still don't get why it's not done with oidn
can you explain this file ? what's it for ?
https://github.com/LuxCoreRender/LuxCor ... ymbols.map
but even when i add oidn there is does not work
OK let's forget about all that static ! linking .
I found a tool that collects all the libs and patches the exe accordingly. It's called dylibbundler. https://github.com/auriamg/macdylibbundler
So I have working LuxCoreUi_2.3alpha0.zip and BlendLuxCore_2.3alpha0.zip here an my Desktop. checked with the "clean" mac.
Still unsure about luxcoreconsole since we would have to publish it with a lib-subfolder.
I'll post links on my website soon.
OK Files can be found here http://q3de.com/research/luxcorerender-for-osx-10-13/
would you mind me making a new post in news section ? So people will try it.
cheers u3dreal
cheers u3dreal
Re: Compile on MacOS 10.13
I created a post in News section: viewtopic.php?f=9&t=1599
You may want also to write a post with the news in this thread: https://blenderartists.org/t/luxcoreren ... 183292/101
Done .... ssooooo now for a 2.2.Release ??
It seems to be pretty stable... rendered over night for 6 h and everythign seems fine ..... scales great on my xenon 6 core ...
using almost 1.200 % of CPU.
There is a tag in Git for v2.2 ("luxcorerender_v2.2") if you extract the sources, you can compile the v2.2 but it may a bit a waste of time (the sources were using some older version of the libraries so it may be not a trivial task to compile the v2.2 because of dependencies: you may have to compile more stuff). It may be better to focus on v2.3 and the hopefully soon to be released beta1.
