Spheres scene challenge
Re: Spheres scene challenge
Thanks to @sarmath and @DEBIHOOD for fixing this scene!
I'm still mixing rough and dispersive glass for better reflections:
Martini
Post by Martini »
@DEBIHOOD
Congratulations, you've won a prize! :lol:
Here is 2 CFiu (2 binary CarbonFlux units :ugeek:) render
Time: 19:40:58.38 | 20,480 Samples | 599k Samples/Sec | 17.5 Rays/Sample | Bidir CPU + Metropolis
Composite
Composite
Raw render output
Raw render output
epilectrolytics wrote: Mon Sep 23, 2019 8:08 am Thanks to @sarmath and @DEBIHOOD for fixing this scene!
How did you get the incoming beam to show up?
I tried to fix that yesterday, but failed :?
B.Y.O.B. wrote: Mon Sep 23, 2019 9:30 am How did you get the incoming beam to show up?
I have no idea :oops:
I just took this file and modified it:
Luxcore spheres blend.7z
I think darker tile colors help the beams to shine.
Last edited by epilectrolytics on Mon Sep 23, 2019 5:30 pm, edited 1 time in total.
epilectrolytics wrote: Mon Sep 23, 2019 9:59 am I think darker tile colors help the beams to shine.
It looks also a lot better in my opinion.
DEBIHOOD
Post by DEBIHOOD »
Martini wrote: Mon Sep 23, 2019 8:31 am Here is 2 CFiu (2 binary CarbonFlux units :ugeek:) render
Thank you so much :D :D
It looks just fantastic inspiring :)
sarmath
Post by sarmath »
Dade wrote: Mon Sep 23, 2019 10:42 am
Yes dark themed from epilectrolytics looks cool :)
When I switch (in my version of the file 4 posts above) to Hybrid I can reproduce the missing initial beam.
And also the caustic beams get way too bright (compared to BiDir) :?
No matter if CPU or OCL, with and without rough glass material component.
epilectrolytics wrote: Mon Sep 23, 2019 5:28 pm When I switch (in my version of the file 4 posts above) to Hybrid I can reproduce the missing initial beam.
It sounds like a wrong world volume setup :?:
Dade wrote: Mon Sep 23, 2019 5:45 pm It sounds like a wrong world volume setup :?:
There is a fog box around the room, the camera and emitters are outside and no world volume defined.
When I define one and assign it as exterior to the fog box and the emitters, there is no change in rendering, still no incoming beam and the caustic beams are too bright.
(I think @FarbigeWelt has somewhere tested BiDir against Hybrid with lasers and volumes and found similar inconsistencies.)
