dark juice
Re: dark juice
hm, it only works in your scene with artificial lighting. When I use sun and sky and no clamping I don't get much sun inside the glass
I would expect something more like this
Re: dark juice
hm, so it doesn't work...
here's your juice in glass as you set it up but this time with sun and sky here it is juice object only and here it is juice only but this time architectural glass so only the last one shows proper gradient from sunlight inside the volume (closer to reference photo in my previous post)
scene with sun and sky
Re: dark juice
i can confirm the strange look under sun and sky. maybe Dev give an input when they're back.
Re: dark juice
My version:
Only lit by Sun + Sky.
- Attachments
- juice1.blend
- (724.7 KiB) Downloaded 590 times
Re: dark juice
Thanks, I'll check it in the morning I'm not at pc atm.
But now the refraction looks a bit odd near the top and the very top still kinda looks darker than I'd expect under direct sun...
How is it modelled? what's the glass shader like?
Re: dark juice
You can tweak it further, on my slow computer it is hard to find the perfect settings. But keep in mind, that for commercial beverage photos they use back lighting, so without that you wont get those punchy results.
Re: dark juice
Camera volume should be disabled, because it makes nonsense all the time.FarbigeWelt wrote: Wed Aug 14, 2019 10:35 am Camera volume should be set to air too. Automatically detection makes nonsense sometimes, with very strange results due to wrong refractive index ior or other settings.
Re: dark juice
This juice's volume has priority 0, the same as glass. Glass should have higher priority. Also, juice ior = 1.5, which is uncommon for juice (unless it's 85% sucrose).lacilaci wrote: Wed Aug 14, 2019 12:49 pm here's your juice in glass as you set it up but this time with sun and sky
Re: dark juice
juice_sunsky.blend (with volume priorities and ior fixed)
Path+Sobol ~
Bidir+Metropolis~
I like bidir version better. It is three times faster and ten billion times better.
Path+Sobol ~
Bidir+Metropolis~
