Vutshi wrote: Fri Sep 20, 2019 1:25 pm BTW, I tried the smallpt code from the Supplemental Material and it is broken :). After fixing it seems to work but produces a bit more fireflies as compared to the figure in the SM. It does not darken as far as I can see.
And have you seen how many samples it takes just to have a vague caustic and few fireflies ?
Vutshi
Post by Vutshi »
Dade wrote: Fri Sep 20, 2019 2:21 pm And have you seen how many samples it takes just to have a vague caustic and few fireflies ?
These are 128 and 2048 samples per pixel, respectively.
provisory
Post by provisory »
Is this metropolis? Doesn't look like.
provisory
Post by provisory »
And in the SM there is a 65536 samples per pixel image of this scene.
Vutshi
Post by Vutshi »
provisory wrote: Fri Sep 20, 2019 2:41 pm Is this metropolis? Doesn't look like.
No it is regularised path tracing inspired by the code in the paper.
My initial plan was first to understand smallpt with Path Space Regularization and then apply it to smallmmlt. But smallmmlt is above my poor understanding of all this stuff. They don't even have glass material there :)
EDIT:
Here is 2^17 samples per pixel. Looks noisy to me I guess I messed up something :)
image_new_small 217v2.png (16.84 KiB) Viewed 22949 times
Sharlybg wrote: Fri Sep 20, 2019 1:42 pm
lacilaci wrote: Fri Sep 20, 2019 12:27 pm starting to look good. (except the overall darkness underwater)
what about sun+sky or HDRi
This is sun+sky (with the same exposure so it is a bit over-exposed due the additional light source):
Note: the water volume of the scene has (a bluish) absorption (so it does intentionally take away some light).
Now it is clear that with sun+sky this water should be a loooot more clear than that. There is surely a terrible wrong thing going on here :shock:
It would be interesting to see this scene without absorption.
If this scene is derived from my test pool here it probably contains a volume setup error because I used only a water (ocean modifier) plane and no solid block.
The underwater pool tile object then has not the absorption volume properly assigned as exterior.
But with just killing all volumes it should render properly (I guess).
epilectrolytics wrote: Fri Sep 20, 2019 4:16 pm If this scene is derived from my test pool here it probably contains a volume setup error because I used only a water (ocean modifier) plane and no solid block.
I think this is not a problem, because rays keep their volume when the material they hit doesn't have one assigned (if I remember correctly).
Since all rays pass through the water surface on entry and exit, it should work. It would be a problem though if you were to dip the camera below the water surface without assigning the water volume as exterior camera volume.
