Env. Light Visibility Cache
Dade wrote: Sun Jul 21, 2019 12:50 pm I added the OpenCL support for Env. Light Visibility Cache, it now works with GPUs too.
P.S. 3 days to find a damn bug (who ended to be not related to Env. Light Visibility Cache at all) :roll:
will give it some proper testrun tomorrow...
fingers crossed
zuljin3d
Post by zuljin3d »
Tried the last build.
Does the cache work by default? No need to choose options here?
Feels like noise disappears quickly. 8-)
But if you add normal map to the material,luxcore produces an error: "PathOCLBase kernel compilation error".
last nvidia driver gtx960 BlendLuxCore 2_79_maintenance (light tracing)
1 Min render
1 Min render
zuljin3d wrote: Sun Jul 21, 2019 6:37 pm Does the cache work by default? No need to choose options here?
No, you have to go into the world settings, performance panel, and switch the map type from "single" to "cache".
zuljin3d wrote: Sun Jul 21, 2019 6:37 pm But if you add normal map to the material,luxcore produces an error: "PathOCLBase kernel compilation error".
Can you post the full log with the traceback?
zuljin3d
Post by zuljin3d »
B.Y.O.B
Just according to my feelings, the cache is enabled by default,if use opencl.
I do not know how to do this?
  File "C:\Users\start\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore-2_79_maintenance\engine\__init__.py", line 85, in render_final
    final.render(self, scene)
  File "C:\Users\start\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore-2_79_maintenance\engine\final.py", line 40, in render
    _render_layer(engine, scene, render_slot_stats)
  File "C:\Users\start\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore-2_79_maintenance\engine\final.py", line 63, in _render_layer
    engine.session.Start()
RuntimeError: PathOCLBase kernel compilation error
ERROR: PathOCLBase kernel compilation error
none
none
cache
cache
zuljin3d wrote: Sun Jul 21, 2019 8:05 pm Just according to my feelings, the cache is enabled by default,if use opencl.
Trust me, I wrote the code. By default, only the old single visibility map is used.
https://github.com/LuxCoreRender/BlendL ... ght.py#L86
But maybe I misunderstand what you mean?
Can you post a test scene triggering the error ?
zuljin3d
Post by zuljin3d »
Dade wrote: Sun Jul 21, 2019 9:03 pm
I tried my old scenes, the problem always appears when there is material with a normal map in the scene.
Error.zip
(3.42 MiB) Downloaded 549 times
First of all, this error:
aaand on cpu this one:
Single Map used, forgot to set Env. Cache... :oops:
But is rendering now. Without errors. :)
Ok,
Here are some of my findings in a testscene where it works on both cpu and opencl (previous errors and crashes I posted happen on a big scene)
First test is luxcore with different settings for visibility map against cycles with and without portals
I set halt conditions for luxcore to 1 minute which results in ~500 samples and cycles is set to 1024 samples which is ~ 57 seconds
Both running in cpu+gpu mode on ryzen2700+rtx2070
scene is identical with small exception that I didn't match exactly the tile size on checker and exposure might be a little off too, but it still illustrates my points so it is close enough.
So, this is cycles without portals:
and luxcore with visibility map set to NONE:
and luxcore with default visibility map setting, SINGLE MAP
It already looks pretty bad for luxcore when it comes to direct light performance
Also note that default single map is near useless in this testscene. I build the scene this way intentionally cause I've experienced this in few production scenes already (many obstruction objects between camera and openings in interior - map won't cover complex scene). It only works in very basic setup(single opening in scene and direct exposure from that opening on objects)
This is luxcore's new cache:
and cycles with portals:
Again, not only portals are without performance penalty (luxcore's visibility cache can easily take around 1 minute to build! in semi-complex scene)
Portals also don't give artifacts (those won't go away in luxcore even after 2000 samples and they throw off intel's denoiser so the resulting render will either have noisy patches or smudgy patches in it)
And it also seems that (at least in cycles's case) portals still give cleaner results than cache even in areas where cache works!
Also, on the topic of visibility map as a whole.
this is default setting (visibility map set to SINGLE MAP)
and this is visibility map set to NONE:
Again, intentional setup of the scene, I've seen this happen again and again in product viz scenes (just hdri+object).
Visibility map cannot handle these open scenes just as it cannot handle interiors with many openings and obstructions.
What's worse it is ON by default and in blender it is away in scene environment setting (nobody would think it damages performance, I found out by accident)
So I don't know how work in progress this cache is and what can be done about it's performance and those artifacts.
But I'm gonna assume it won't get much faster and those artifacts will always show up somewhere, so in that case:
[warning: just my personal opinion, no need for pitchforks]
I would say, this visibility map while in many cases can help a bit. It needs user to do some testing to figure if it works in his case! So not so automatic in the end(in fact it's less automatic than portals at this moment).
What's worse, If I figure that in my productviz scene it is worse having it on I can turn it off. But in my complex scene I will not have a solution for bad direct light illumination at all! Half working cache is not a solution cause it's unreliable with those "patches"
So while I would prefer a fully automatic setting without caring about portals, there is no such thing in luxcore.
I would rather spend a while setting up portals in openings knowing what result to expect, than having to test in every single scene:
If the vis.map works better on or off, what mode works better, if those patches appear and do they all go away, if they go away how long it takes and is it not better to just use single map...
I'm sorry if I speak too soon and you have some solutions in the works! I'll happily re-test anything any time there's an update to this, since luxcore really needs some boost for direct lighting. (it's the last piece of the "puzzle" to make luxcore fucking fast!)
279_luxcore.blend
(2.52 MiB) Downloaded 594 times
