Luxcore Preset Mode
Re: Luxcore Preset Mode
Sorry I didn't answer.
I looked at the code and as far as I could see, the Blender API doesn't give me the option to jump to an arbitrary place in the list.
As a workaround I could put the entry for the current material to the top of the list so it is selected by default. However, this will rip it out of the alphabetically sorted list.
Would this help you? What's the reason for your request?
placed at the top of the list
Suppose 5 different version of the same Material and their start with same word " Wall_ + number" :
Wall__01
Wall__02
Wall__03
wall__04
Wall__05
In cycles when you click on a given material you jump right to that material in the list so you can select easily any surrounding material with same start name.
Sometime material name have a link with the object they are applied to :
Ferrari__Paint
Ferrari__logo
Ferrari__rim
Ferrari__tyre
Ferrari__light
Anyway if it isn't possible we can live without it . search tool is the long way but .... ;)
Ok, so putting it at the top of the list would not help.
You will have to type in the start of the name manually.
B.Y.O.B. wrote: Tue Mar 05, 2019 4:29 pm Ok, so putting it at the top of the list would not help.
If you can check what material is selected then you have the material name. You can take the first 2 to 4 letters as string part.
Now the question is: Can you past the string part into the entry field? If yes materials would be showed in the list below input based on these 2 to 4 letters and all other materials were omitted.
I don't think so: https://docs.blender.org/api/2.79/bpy.t ... arch_popup
And anyway, it's not a good idea, because by default you want to show a list of all materials without a search typed in for you already.
B.Y.O.B. wrote: Wed Mar 06, 2019 3:12 pm I don't think so: https://docs.blender.org/api/2.79/bpy.t ... arch_popup
There seem to be many approaches.
https://blender.stackexchange.com/quest ... /8814#8814
If you want you can take on this problem.
Here's the operator code: https://github.com/LuxCoreRender/BlendL ... al.py#L123
and UI code: https://github.com/LuxCoreRender/BlendL ... ial.py#L55
B.Y.O.B. wrote: Wed Mar 06, 2019 6:00 pm If you want you can take on this problem.
Okay. I take this one. It is still a bit riddle why Blender API is built the way it is. I find it quite strange and the reference is something I am not amused. On the other hand the user data structure with all its objects and nested data is rather easy to be accessed and changed.
Basic UIList Example
bpy.types.bpy_struct.id_data
The Blender Python api allows integration for:
bpy.types.Panel
bpy.types.Menu
bpy.types.Operator
bpy.types.PropertyGroup
bpy.types.KeyingSet
bpy.types.RenderEngine
And this is maybe why I cannot use UIList directly. I go to have a further look at it.
thanks for that ;)
Sharlybg wrote: Fri Mar 08, 2019 11:20 am
thanks for that ;)
Do you have a good pain killer? My nack woar, my head soar ..
I guess I think completelly different than the great qhosts whou spelled this biliniear dichrome version of a polyvariant Gordon's knot streched beyond touchable finesse on topogical wrongly terminated Moebius' stripe.
Rather I'm going to buy the s e v e n most probably worthiest coder books at date; and read them from scratch.
I mean the books fromDonald Ervin Knuth The Art of Computer Programming (TAOCP).
