Spot light with image as a pattern
DorPrz
Re: Spot light with image as a pattern
Post by DorPrz »
BTW after disabling the world light the "bad renders" went completely black.
I rendered 100 images with Path OpenCL and each one was correct.
However I rendered with OpenCL on CPU device because my notebook does not have a GPU.
The fact that it fails on your GPU could mean that your GPU driver has a bug in its OpenCL compiler.
I made some changes as I mentioned, if you want you can test it with the modified file if it also fails on your GPU:
untitled (2).blend
(553.25 KiB) Downloaded 290 times
DorPrz
Post by DorPrz »
I had 1 bad render on a CPU, Can you test a little more? maybe 1000 renders?
Specifically testing Spot Light with image pattern (.bmp) on 100 frames.
It is rendering fine using OCL Path on GTX 1060 6GB.
Sys. specs: driver version 391.74, Windows 7SP1 x64, Blender 2.79b
Just not after first set of changes (applying realistic values).
1. World
=> None
2. Spot Light
Gain = 1
Power (W) = 1500, Efficacy (lm/W) = 17
3. Camera
=> LuxCore Imagepipeline / Tonemapper / Use OpenCL (on)
=> Camera Setings
F-stop: 4, Shutter (s): 1/20, ISO: 400
Results vary in lighting & 3 black frames.
Have observed similar behavior before, issues when Camera or lights are positioned on XYZ (0,0,0), so i checked coordinates.
Then, after another change: Spot Light moved on X to 0.01, all went smooth. ;) Right.
Am not sure but, IIRC, it's some kind of bug :?
kintuX wrote: Thu Sep 06, 2018 10:23 pm Have observed similar behavior before, issues when Camera or lights are positioned on XYZ (0,0,0), so i checked coordinates.
Nice find, this is most likely the cause.
It's probably a bug triggered by numerical precision issues.
In general it is a bad idea to place stuff exactly at the world origin (in any renderer).
The Nvidia OpenCL compiler seems to make the problem more likely.
