Modules Installed (BlendLuxCore) from 'C:\\Users\\Usuario\\Downloads\\BlendLuxCore-v2.1alpha1-win64-opencl.zip' into 'C:\\Users\\Usuario\\AppData\\Roaming\\Blender Foundation\\Blender\\2.79\\scripts\\addons'
File "F:\Install\blender-2.79b-windows64\2.79\scripts\modules\addon_utils.py", line 331, in enable
mod = __import__(module_name)
File "C:\Users\Usuario\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\__init__.py", line 13, in <module>
from .bin import pyluxcore
ImportError: DLL load failed: No se puede encontrar el m├│dulo especificado.
minimum = 4 if is_big_image else 1
maximum = 16
to
minimum = 128 if is_big_image else 1
maximum = 512
The values I used here are a compromise. Note that a refresh does not just update the stats and film, it also checks for halt conditions. So if you set the maximum to 512 seconds and choose a halt time of 300 seconds, the render will halt after 512 seconds.
I know that this is the first release of the Direct Light Cache so there will be space for development, but I'd like to know if it'll be developed the lightcache samples filtering to smooth the lightcache solution.
marcatore wrote: Wed Jul 04, 2018 7:30 am
