Lamps
Re: Lamps
I added an issue entry: https://github.com/LuxCoreRender/BlendLuxCore/issues/57
It is not exactly a non-trivial 10 minute thing to implement, but maybe I can do it in the next days.
Re: Lamps
B.Y.O.B. wrote: Tue Jan 23, 2018 8:59 pm I added an issue entry: https://github.com/LuxCoreRender/BlendLuxCore/issues/57
BTW, just in case, this is the Python code to list the available OpenCL devices: https://github.com/LuxCoreRender/LuxCor ... emo.py#L99
david57
Re: Lamps
Post by david57 »
The CPU option had already been disabled.
I do not know how to check how much memory the graphic cards are using.
Where or how is that done?
Re: Lamps
The program GPU-Z can display that information on Windows.
david57
Re: Lamps
Post by david57 »
I just tried Sobol and crashed with that also.
Re: Lamps
You can also try to update your graphics card drivers.
OpenCL crashes are sometimes caused by the driver.
david57
Re: Lamps
Post by david57 »
I just downloaded the GPU-Z and will try that.
Graphic card drivers were updated just a few weeks ago.
david57
Re: Lamps
Post by david57 »
The memory usage while rendering was 1107 MB for dedicated.
It did not crash this time while in Metropolis.
david57
Re: Lamps
Post by david57 »
It crashed again. It crashes as soon as I click render.
The memory read 770MB and did not change when I clicked the render.
Re: Lamps
david57 wrote: Tue Jan 23, 2018 10:22 pm It crashed again. It crashes as soon as I click render.
What GPU do you have ?
