Dade wrote: Mon May 07, 2018 9:39 am
Going to try Windows.
It seems to be a Windows-only problem Going to check what is going on.
The only problem on Windows seems a division by zero on an elapsed time due to the very low timer resolution. However I was getting an explicit error, not a freeze like you. Once I fixed the division by zero, it works fine here:
Can you try if this (https://drive.google.com/file/d/1bf662u ... sp=sharing) pyluxcoretool.exe is working for you ? I have the feeling that the division by zero isn't your problem.
As you expect it doesn't change SiR Sherlock holmes !
The cube scene is working on my Win 10 machine with the build i did when last commit in github was e0c7ca3.
I don't have over 1 machine in home, so i can not test real network render. But slave and master on same machine works.
I only have python 3.7.3 installed, not sure if it matters, but at least for building pyluxcoretool.exe
i had to remove all python versions, manually remove folders in program files and app data with remaining python files, install python 3.7.3 and PyInstaller and PySide and NumPy.
