Unified executable (for CPU-only, OpenCL and CUDA)
Re: Unified executable (for CPU-only, OpenCL and CUDA)
Windows never stop to amaze me (a limited stack size in 2020...), I should have fixed the problem in the latest sources.
OSX works fine
NVIDIA and APPLE drivers. Using LUXRAYS_ENABLE_OPENCL and LUXRAYS_ENABLE_CUDA .
Also a sidenote compilation time
CUDA 3min
NV OPENCL 6min
APPLE OPENCL 14min
Will test on APPLE AMD drivers this evening.
CUDA 3min
NV OPENCL 6min
APPLE OPENCL 14min
portfolio http://q3de.com/
Defining symbols should be not required any more. Binaries will have now always the potential ability to work with CUDA and OpenCL if the drivers are available when run.
You can use LUXRAYS_DISABLE_OPENCL and LUXRAYS_DISABLE_CUDA if you really want to produce binaries that can not support GPUs (but it should be never required).
Well then i will have to find out how to compile with cuda on a system that does not support cuda...
But it is files and libs after all ..
luxcoreui seems to be liked against
Does cuda get linked in statically ???
there does not seem to be a dynamic dependency anymore ??
MacBook-Pro:LuxCore drquader$ otool -L build/Release/luxcoreui
build/Release/luxcoreui:
@rpath/libomp.dylib (compatibility version 5.0.0, current version 5.0.0)
/System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa (compatibility version 1.0.0, current version 23.0.0)
/System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL (compatibility version 1.0.0, current version 1.0.0)
/System/Library/Frameworks/IOKit.framework/Versions/A/IOKit (compatibility version 1.0.0, current version 275.0.0)
/System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation (compatibility version 150.0.0, current version 1560.12.0)
/System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo (compatibility version 1.2.0, current version 1.5.0)
@rpath/libembree3.3.dylib (compatibility version 3.0.0, current version 3.0.0)
@rpath/libOpenImageDenoise.0.dylib (compatibility version 0.0.0, current version 1.2.0)
@rpath/libtbb.dylib (compatibility version 0.0.0, current version 0.0.0)
@rpath/libtiff.5.dylib (compatibility version 11.0.0, current version 11.0.0)
/usr/lib/libz.1.dylib (compatibility version 1.0.0, current version 1.2.11)
@rpath/libOpenImageIO.1.8.dylib (compatibility version 1.8.0, current version 1.8.13)
/usr/lib/libc++.1.dylib (compatibility version 1.0.0, current version 400.9.4)
/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 1252.200.5)
/System/Library/Frameworks/AppKit.framework/Versions/C/AppKit (compatibility version 45.0.0, current version 1671.10.106)
/System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics (compatibility version 64.0.0, current version 1247.4.1)
/System/Library/Frameworks/Foundation.framework/Versions/C/Foundation (compatibility version 300.0.0, current version 1560.12.0)
/usr/lib/libobjc.A.dylib (compatibility version 1.0.0, current version 228.0.0)check out my newest stuff http://q3de.com/research/
You don't need any OpenCL or CUDA header or library to compile the code, it is the magic of dynamic loading of DLLs.
which files are needed by lux then ??? only the installed driver ?So i will not have to add any .dylib files ?? And no patching
That sounds unbelievable
This will make things alot easier ...
I think that the NVRTC DLLs are still needed, they are not shipped with the drivers.
The unified executables seem to work fine on Windows, both standalone and in blender.
Defining LUXRAYS_DISABLE_CUDA and LUXRAYS_DISABLE_OPENCL seems to have no effect: LuxCoreUI still allows to choose OCL render engines. I'll try to check why this happens.
What is so bad about that ? On Linux you can use NVIDIA and AMD GPU together ... i plan to do that ...acasta69 wrote: Thu May 28, 2020 7:27 pm LuxCoreUI still allows to choose OCL render engines. I'll try to check why this happens.
What dlls do you need to copy ??
Well, nothing so bad I guess...u3dreal wrote: Thu May 28, 2020 7:59 pm What is so bad about that ? On Linux you can use NVIDIA and AMD GPU together ... i plan to do that ...
Only, it's not the expected behaviour...
The needed DLLs on Windows are nvrtc64_101_0.dll and nvrtc-builtins64_101.dll.
They are not included in drivers, they come with the SDK and Nvidia allows to redistribute them.
If they are missing, the unified executable does not find CUDA.
