HDRi and Light Tracing
Re: HDRi and Light Tracing
Check the number of native threads you have in OpenCL, it must be > zero. It renders fine here.
jgrover110
Post by jgrover110 »
CPU threads are set to auto-detect, which come up as 8 for me.
I tested it here (win10, Bl2.81, Lux 2.4 daily from ~3 days ago) and it works fine. I downloaded you scene, rendered directly (CPU), switched to OpenCL setting, rendered again.
CPU:
OCL:
EDIT: Looks a lot brighter than your pictures though...
jgrover110
CodeHD wrote: Thu Apr 09, 2020 10:39 pm EDIT: Looks a lot brighter than your pictures though...
That would be because I use the ACES tonemapping
jgrover110
Did a fresh install of latest Blendluxcore, same problem.
How about the OpenCL/GPU drivers? This wasn't mentioned in this thread yet, and dirver problems have occured in the past.
What are you system specs actually?
jgrover110
Ryzen 5 2400g
Radeon Rx570
Radeon Software 20.2.1
I'll update and test again tomorrow
jgrover110 wrote: Thu Apr 09, 2020 11:18 pm I'll update and test again tomorrow
Try to check also your CPU load during the rendering :idea:
Tested and confirmed - working fine w/o any visual difference in CPU vs OCL rendered images (even when using ACES color management).
jgrover110
Dade wrote: Fri Apr 10, 2020 12:22 am
Updated to 20.4.1, still not correct. CPU load reaches 100% in task manager. This must be hardware specific if other people cannot reproduce it.
