Dual xeon performance
Re: Dual xeon performance
Hi, we did extensive tests on AWS. Same behaviour. Till 28 cores everything fine. Rendering with 96 cores is three times slower as the 28 cores machine. Do you need precise details? Can we help?
daros wrote: Tue Dec 17, 2019 10:10 am Hi, we did extensive tests on AWS. Same behaviour. Till 28 cores everything fine. Rendering with 96 cores is three times slower as the 28 cores machine. Do you need precise details? Can we help?
As written before, I need access to the test machine to investigate what is going on.
Hi Dade, fine. We have to setup for you a special machine because we cannot give the access of the machines we are currently using. Probably within 10 days we can give you full access to one or two xeon 2698 V4 with 80 cores. In the meanwhile thanks!
