glossy translucent and bump
Re: glossy translucent and bump
I may have been able to reproduce the problem, with bump map:
without:
Dade wrote: Fri Aug 23, 2019 7:27 am
provisory wrote: Thu Aug 22, 2019 5:47 pm
Dade wrote: Thu Aug 22, 2019 5:15 pm ...it would be a lot easier to investigate with a simpler scene.
Here is a simple test scene.
I get this rendering with glossy translucent:
and this with matte:
where is the problem in glossy translucent ?
I modified provisory's scene to better show the problem
just enable/disable bump to see what's up
bump on:
bump off:
as you see translucency is not working with bump
scene
translucent-vs-bump_mod.blend
(2.73 MiB) Downloaded 268 times
provisory
Post by provisory »
I thought it was quite visible in the original scene... :?
Without bump:
With bump:
I should have fixed the problem. The shadow terminator fix was cutting transmitted light. It wasn't a glossy translucent specific problem but something affecting all diffuse/glossy and transmitting materials.
provisory
Post by provisory »
Thank you!
I'll test it when it's released.
Dade wrote: Fri Aug 23, 2019 8:50 am I should have fixed the problem. The shadow terminator fix was cutting transmitted light. It wasn't a glossy translucent specific problem but something affecting all diffuse/glossy and transmitting materials.
Looks fine now.
provisory
Post by provisory »
Hmm, it doesn't work for me, and the file dates in the build are yesterday morning...
I think the deployment has failed:
https://dev.azure.com/LuxCoreRender/Lux ... mentId=396
provisory wrote: Fri Aug 23, 2019 12:06 pm Hmm, it doesn't work for me, and the file dates in the build are yesterday morning...
The upload of files to GitHub failed, I re-deployed the files and now they should be all up to date.
provisory
Post by provisory »
It works fine now!
Dade wrote: Fri Aug 23, 2019 8:50 am It wasn't a glossy translucent specific problem but something affecting all diffuse/glossy and transmitting materials.
With the previous version I could reproduce the problem with rough glass too, but that is also good now.
