Glossy with Object Motion Blur bug
Re: Glossy with Object Motion Blur bug
I should have fixed everything, this is the original animation posted:
Thanks dade ! hope you're fine with all that reboot coding / fixing stuff ;)
There's still a small bug lingering... only case with Area Lamps (Point & Spot are fine)
[only tested with LuxCore Display]
- This is fine:
- Now activate Motion Blur & go 1 frame forward:
Area light + motion blur seems to work fine here:
Can you post the scene ?
Dade wrote: Sat Feb 17, 2018 10:04 am Area light + motion blur seems to work fine here:
it's same as already posted here (i'm on windows)
Steps taken:
1. turn Spot lamps into Area lamps
2. activate Motion Blur: Object (in Camera)
3. start LuXCore Display
4. move 1 frame forward or back <this is necessary (i assume Area Lamp becomes visible)
5. Render :o :lol:
Final Scene file saved
Atollo238_Area-bug.zip
(787.83 KiB) Downloaded 339 times
Looks like a bug in the addon (transformation applied wrong).
