Dirt/Fingerprints on Glass
Re: Dirt/Fingerprints on Glass
Finger prints on glass, using roughness:
Taka
Post by Taka »
From my testing as you can see at the beginning of this post, using rough option makes the glass quite darker.
Taka wrote: Fri Apr 05, 2019 6:28 pm From my testing as you can see at the beginning of this post, using rough option makes the glass quite darker.
Yes, i too found it too strong at first. But that's why "Math Divide" node is there, to lessen the effect.
PS
Here I divided by 25 & set Glass Color to pure White:
& Divided by 50:
Taka
Post by Taka »
Thanks kintuX,
Here is another test using rough option.
First image regular glass
Second image rough option enabled, roughness set to 0.001(lowest I can set)
As you can see, something is not right.
Why not mix glass with matte?
Also instead of a texture driving roughness directly the texture could mix clear glass with rough glass (instead of matte), minimising the darkening effect.
Taka
Post by Taka »
epilectrolytics wrote: Fri Apr 05, 2019 9:06 pm Why not mix glass with matte?
That works well! Thanks
B.Y.O.B. wrote: Fri Apr 05, 2019 5:15 pm On Nvidia GPU, it looks exactly like on your end (green with PathOCL, blue with RTPathOCL).
On Intel OpenCL CPU device, it's also wrong, see attached image.
Maybe a bug in LuxCore after all?
I should have fixed this problem: it was a bug when using glossy coating with pure specular materials (i.e. glass, mirror).
Fox
Post by Fox »
Dade wrote: Wed Apr 10, 2019 10:07 am
Maybe this fix is not yet in BlendLuxCore, or it's another bug, or not bug at all.
The rough glass with roughness of 0.001 has very strong transmissino color. Set the reflection color to pure red, and roughness of 0.001.
Mixed with clear glass, you need mix factor of 0.000001 in favor of clear glass, to make the rough glass red transmissino color fade out.
There are no changes required in the Blender addon to use this fix.
However, the latest daily build does not yet contain the fix: https://github.com/LuxCoreRender/LuxCore/commits/master
Fox
Post by Fox »
B.Y.O.B. wrote: Wed Apr 10, 2019 3:04 pm There are no changes required in the Blender addon to use this fix.
I did build with last commit 6e4635d,
The attachment red test.jpg is no longer available
