I will do, there is some things I need to sort out, there's settings that just don't work which I think broke when the guy updated to Sketchup 2017
I'd rather it export cfg and scn files
I don't what to be that guy who says "I'm doing a plugin" then fail dismally
Nested groups break in Lxs import
Re: Nested groups break in Lxs import
I fixed the light export, however the emitter can't be in a group
Many Sketchup components and lights
If you post a test scene I can look into the problem.nigec wrote: Sat Mar 30, 2019 6:48 am I fixed the light export, however the emitter can't be in a group
here you go
It has a grouped light and a simple plane
- Attachments
lighttest2.zip- (6.55 KiB) Downloaded 304 times
This problem was more the result of a bug than a missing feature. I should have fixed the problem.
great stuff thank you
Just to let you know the emitters work fine now
thanks again
thanks again
