PhotonGI cache
lacilaci
Re: PhotonGI cache
Post by lacilaci »
Dade, how is glossines threshold handled when there is a glossines map used??
Re: PhotonGI cache
lacilaci wrote: Tue Feb 12, 2019 6:52 am Dade, how is glossines threshold handled when there is a glossines map used??
What do you mean with glossiness map ? A texture applied to glossy UV roughness ? In that case, the average texture value is used for the comparison with the threshold.
Re: PhotonGI cache
But I still get weake light in GI (using same depth for photons as for GI)
Isn't that a side effect of caching being a biased Solution ? :?
Re: PhotonGI cache
lacilaci wrote: Tue Feb 12, 2019 4:53 am Are all shaders supported now?
Cache entries are still created only on "DIFFUSE | REFLECT" and "GLOSSY | REFLECT" materials. I will start to lift that limitation only after everything is more stable and all major problem has been fixed. We are pretty near to that point.
Re: PhotonGI cache
Sharlybg wrote: Tue Feb 12, 2019 9:40 am
It is a factor but the difference is still a bit too high, there may be a bug. I will check after I have tried the same solution with caustic cache.
lacilaci
Re: PhotonGI cache
Post by lacilaci »
Dade wrote: Tue Feb 12, 2019 9:42 am
I'm also getting strong cache samples near corners (larger lookup radius helps in some cases but there is often few samples that are too bright).
It reminds me of the problem you had before, where you had strong fireflies near corners, but now it seems there are often strong cache samples near corners while more away from corner they are weaker than pathtracing.
lacilaci
Re: PhotonGI cache
Post by lacilaci »
here's how that bleeding looks. I'm getting this everywhere (probably related to glossy reflection ?)
lacilaci
Re: PhotonGI cache
Post by lacilaci »
BTW on the topic of caustics... could reflective caustics be handled similar as gi (cache not directly visible) and specular caustics separately(directly visible)?
Re: PhotonGI cache
lacilaci wrote: Tue Feb 12, 2019 10:18 am here's how that bleeding looks. I'm getting this everywhere (probably related to glossy reflection ?)
My Blender 2.79b says the scene has been written with 2.80 and crashes :?:
lacilaci
Re: PhotonGI cache
Post by lacilaci »
Dade wrote: Tue Feb 12, 2019 11:14 am
I'm sorry, wrong file...
here:
00_concept_lux.zip
