yes...it's really really similar to Vray Lightcache!!!Dade wrote: ↑Mon Feb 11, 2019 2:37 pm A new code using regular visibility points:
The light intensity is a lot more uniform and smooth, thanks to the uniform distribution the cache look up is also 2 times faster (check the samples/sec) and independent from number of photon traced or look up radius. The pre-processing is also a lot faster.
P.S. this starts to looks exactly like a V-Ray output...
Good job.
