OpenImageDenoise
lacilaci
Re: OpenImageDenoise
Post by lacilaci »
B.Y.O.B. wrote: Tue Feb 05, 2019 8:44 pm
lacilaci wrote: Tue Feb 05, 2019 8:35 pm If you can solve this, you might also get ready to implement albedo and avg normal pass for bidir.
Dade already did this.
In blender the aov Avg. Shading Normal is grayed out, but it can be checked and works. So that what confused me.
lacilaci wrote: Wed Feb 06, 2019 5:40 am @B.Y.O.B. - Denoised pass doesn't have alpha in blender. My transparent background is black in the denoised pass, can be something done about that?
Maybe in the future, for now I would recommend to enable the Alpha AOV and use the compositor to make the denoised output transparent.
lacilaci wrote: Wed Feb 06, 2019 6:52 am In blender the aov Avg. Shading Normal is grayed out, but it can be checked and works. So that what confused me.
Thanks for the reminder, I updated the UI.
It works !
The problem was in the implementation of the "NONE" pixel filter, I "simplified" the way it works and now Oidn recognize the noise and works with BIDir (no problem with Metropolis too):
Yuppie !
@B.Y.O.B.: you should always force the "film.filter.type = NONE" with BIDir+Oidn in BlendLuxCore.
lacilaci
Post by lacilaci »
Dade wrote: Wed Feb 06, 2019 11:20 am It works !
Yuppie !
Oh boy, this is amazing... is there a build?
lacilaci wrote: Wed Feb 06, 2019 11:25 am Oh boy, this is amazing... is there a build?
It is cooking: https://dev.azure.com/LuxCoreRender/Lux ... uildId=200
Post by FarbigeWelt »
Congratulations, Dade!
And sure for all others involved in this exceptional performance.
(I am close to be speaklessly overwhelmd.)
lacilaci
Post by lacilaci »
Dade wrote: Wed Feb 06, 2019 11:27 am
BTW, did you fix the unknown imagepipeline error for linux build? Windows works, and B.Y.O.B. own build worked yesterday aswell but azure linux didn't.
EDIT: To answer my own question, daily builds of linux no longer throw the error aobut uknown image pipeline when using oidn.
Awesome!
Dade wrote: Wed Feb 06, 2019 11:20 am @B.Y.O.B.: you should always force the "film.filter.type = NONE" with BIDir+Oidn in BlendLuxCore.
Done.
Here's a 64 sample render with Bidir + OIDN:
Post by epilectrolytics »
FarbigeWelt wrote: Wed Feb 06, 2019 11:45 am (I am close to be speaklessly overwhelmd.)
Possibly a divine intervention by JAHEW or SIHVA helped to make OIDN work :lol:
lacilaci
Post by lacilaci »
This is incredible... I might actually give bidir a try in some cases!
