In blender the aov Avg. Shading Normal is grayed out, but it can be checked and works. So that what confused me.
OpenImageDenoise
Re: OpenImageDenoise
Maybe in the future, for now I would recommend to enable the Alpha AOV and use the compositor to make the denoised output transparent.lacilaci wrote: Wed Feb 06, 2019 5:40 am @B.Y.O.B. - Denoised pass doesn't have alpha in blender. My transparent background is black in the denoised pass, can be something done about that?
Thanks for the reminder, I updated the UI.lacilaci wrote: Wed Feb 06, 2019 6:52 am In blender the aov Avg. Shading Normal is grayed out, but it can be checked and works. So that what confused me.
It works !
The problem was in the implementation of the "NONE" pixel filter, I "simplified" the way it works and now Oidn recognize the noise and works with BIDir (no problem with Metropolis too):
Yuppie !
@B.Y.O.B.: you should always force the "film.filter.type = NONE" with BIDir+Oidn in BlendLuxCore.
Yuppie !
Oh boy, this is amazing... is there a build?Dade wrote: Wed Feb 06, 2019 11:20 am It works !
Yuppie !
- FarbigeWelt
- Contact:
Congratulations, Dade!
And sure for all others involved in this exceptional performance.
(I am close to be speaklessly overwhelmd.)
BTW, did you fix the unknown imagepipeline error for linux build? Windows works, and B.Y.O.B. own build worked yesterday aswell but azure linux didn't.Dade wrote: Wed Feb 06, 2019 11:27 amIt is cooking: https://dev.azure.com/LuxCoreRender/Lux ... uildId=200
EDIT: To answer my own question, daily builds of linux no longer throw the error aobut uknown image pipeline when using oidn.
Awesome!
Here's a 64 sample render with Bidir + OIDN:
Done.Dade wrote: Wed Feb 06, 2019 11:20 am @B.Y.O.B.: you should always force the "film.filter.type = NONE" with BIDir+Oidn in BlendLuxCore.
Possibly a divine intervention by JAHEW or SIHVA helped to make OIDN work
This is incredible... I might actually give bidir a try in some cases!
