OpenImageDenoise
Re: OpenImageDenoise
Dade wrote: Mon Feb 04, 2019 3:59 pm It may be a side effect of some internal Oidn behavior: Alpistinho is initializing the Oidn device and filter at the plugin allocation, we could do that for every apply() however it may be slower so I tend to agree with Alpistinho's decision.
If you are talking about the stuff in the constructor, this takes 0.2 ms on my notebook CPU:
OIDN constructor took 0.000236034 seconds
So I would just move it to Apply.
B.Y.O.B. wrote: Mon Feb 04, 2019 4:35 pm So I would just move it to Apply.
Done.
Thanks, the memory hogging is gone.
Dade wrote: Mon Feb 04, 2019 4:28 pm Second try, hopeful fixed now:
Does anybody else observe the lack of depth of denoised images in the first two rows compared to the noisy one in the same line. Is this an illusion of mine, this good visible distance between the left top edge of the plate and the wall in the background?
Beside that, it’s amazing how good oidn works. And even more, how fast and far you got!
MacBook Air with M1
FarbigeWelt wrote: Mon Feb 04, 2019 5:07 pm
Left side of the image is brighter the the right side. When right side is attached to the left side of another rendering it may lead to perceive, a not existing, difference ... but it is really hard to judge as all human perception related things.
Post by lacilaci »
The difference between noisy and denoised image is much much bigger to perception than people think.
Noise is incredibly distracting and I couldn't count how many times I thought everything is fine and then render finals and it's shit without details. Denoiser/or really clean render really shows how good or not the scene etc, is, while noise leaves lot for imagination.
Post by lacilaci »
Ok, so on twitter Attila Afra said that bidir without metropolis should be ok, I can't test now but is this possibe?
Check out @attila_afra’s Tweet: https://twitter.com/attila_afra/status/ ... 45859?s=09
I tested Bidir with Random sampler and the denoiser changed nothing.
Post by epilectrolytics »
B.Y.O.B. wrote: Mon Feb 04, 2019 7:09 pm I tested Bidir with Random sampler and the denoiser changed nothing.
Maybe also test Path metro?
Post by lacilaci »
epilectrolytics wrote: Mon Feb 04, 2019 7:15 pm
path+metro works fine with nvidia. I think it would with intel too. Will test in the morning
