Mac OS
Re: Mac OS
PLEASE TELL ME HOW YOU FIXED IT!jensverwiebe wrote: Sat Jan 20, 2018 4:26 pmThats what i immediately thought when seeing the new embree libs come with @rpath id: rpath is a wonky thing on macOS, i made them loader_path now, works more reliable.AndreD wrote: Fri Jan 19, 2018 6:44 pm Hi,
I am just trying the first mac version,
I get this error:
Traceback (most recent call last): File "/private/var/folders/qr/g00zj9_91m3_xs4l5c5lvykc0000gn/T/AppTranslocation/93244D79-C0F7-42A3-BE5D-378F82ED9B17/d/blender.app/Contents/Resources/2.79/scripts/modules/addon_utils.py", line 331, in enable mod = __import__(module_name) File "/Users/andredupke/Library/Application Support/Blender/2.79/scripts/addons/BlendLuxCore/__init__.py", line 2, in <module> from .bin import pyluxcore ImportError: dlopen(/Users/andredupke/Library/Application Support/Blender/2.79/scripts/addons/BlendLuxCore/bin/pyluxcore.so, 2): Library not loaded: @rpath/libembree.2.dylib Referenced from: /Users/andredupke/Library/Application Support/Blender/2.79/scripts/addons/BlendLuxCore/bin/pyluxcore.so Reason: image not found
Jens
Re: Mac OS
Is this still happening? The rpath/loader path is because of Blender’s self contained Python and addon location. I’m happy to try and figure out another solution if it’s causing problems.
- FarbigeWelt
- Contact:
Re: Mac OS, openCl
Today, I run a few tests with openCl. Sample count and speed of GPU are an not as i expected them.
MacBook Air with M1
MacBook Air with M1
Re: Mac OS, openCl
That's your 2010 iMac?FarbigeWelt wrote: Sat Feb 02, 2019 2:58 pm Today, I run a few tests with openCl. Sample count and speed of GPU are an not as i expected them.
I guess if the GPU is weak there is no point in using it:
It will need CPU power to feed it which in itself would have contributed more to the render than the GPU it supports.
You could launch Activity Monitor and check how much CPU power is needed while rendering on the GPU only.
EDIT: Just spying at your dock it seems a lot of apps are open.
Now when testing render performance I would close all other apps, also networks.
Again Activity Monitor reveals if any background process is eating away CPU capacity.
- FarbigeWelt
- Contact:
Re: Mac OS, openCl
I had the same thoughts, and closed all other apps but without change. I will check with luxmark if it shows the same behaviour.epilectrolytics wrote: Sat Feb 02, 2019 5:56 pm
Based on data sheets I would expect different results from the openCL GPU render. We will see.
MacBook Air with M1
MacBook Air with M1
- FarbigeWelt
- Contact:
Re: Mac OS, openCl
Yes, it is my 2010 iMac.epilectrolytics wrote: Sat Feb 02, 2019 5:56 pm That's your 2010 iMac?
You may have guessed wrongly..
Lux Ball Scene
openCL 1482
CPU 1152
CPU and GPU 2608
MacBook Air with M1
MacBook Air with M1
Re: Mac OS, openCl
Well I'm glad was wrong
Next try: Probably It's the 1GB GPU Ram vs 24GB CPU Ram that's causing the weird results of the former test.
Re: Mac OS
Have you noticed if it's spending forever on the OpenCL Kernel building? I was having issues where depending on how complicated the Scene the OpenCL kernels took forever and that's what made it worse.
- FarbigeWelt
- Contact:
Re: Mac OS
No, I have not noticed it at all.robbrown wrote: Sun Feb 03, 2019 8:35 am Have you noticed if it's spending forever on the OpenCL Kernel building? I was having issues where depending on how complicated the Scene the OpenCL kernels took forever and that's what made it worse.
Look at these compilation times.
[LuxCore][604.525] Starting 1 OpenCL render threads
[LuxCore][604.654] [PathOCLBaseRenderThread::0] Compiling kernels
[LuxCore][604.668] [PathOCLBaseRenderThread::0] Kernels cached
[LuxCore][604.668] [PathOCLBaseRenderThread::0] Compiling Film_Clear Kernel
[LuxCore][604.668] [PathOCLBaseRenderThread::0] Compiling InitSeed Kernel
[LuxCore][604.668] [PathOCLBaseRenderThread::0] Compiling Init Kernel
[LuxCore][604.669] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_RT_NEXT_VERTEX Kernel
[LuxCore][604.669] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_HIT_NOTHING Kernel
[LuxCore][604.669] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_HIT_OBJECT Kernel
[LuxCore][604.669] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_RT_DL Kernel
[LuxCore][604.669] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_DL_ILLUMINATE Kernel
[LuxCore][604.669] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_DL_SAMPLE_BSDF Kernel
[LuxCore][604.669] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_GENERATE_NEXT_VERTEX_RAY Kernel
[LuxCore][604.669] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_SPLAT_SAMPLE Kernel
[LuxCore][604.669] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_NEXT_SAMPLE Kernel
[LuxCore][604.669] [PathOCLBaseRenderThread::0] Compiling AdvancePaths_MK_GENERATE_CAMERA_RAY Kernel
[b][LuxCore][604.669] [PathOCLBaseRenderThread::0] Kernels compilation time: 19ms[/b]
[LuxCore][604.686] Starting 0 native render threads
[LuxCore][604.707] Film OpenCL image pipeline
[LuxCore][604.707] Film OpenCL Device used: ATI Radeon HD 5750 Intersect
[LuxCore][604.707] Device OpenCL version: OpenCL 1.2
[LuxRays][605.276] [Device ATI Radeon HD 5750 Intersect] IMAGEPIPELINE buffer size: 22500Kbytes
[LuxRays][605.276] [Device ATI Radeon HD 5750 Intersect] Merge buffer size: 30000Kbytes
[LuxCore][605.276] [MergeSampleBuffersOCL] Defined symbols: -D LUXRAYS_OPENCL_KERNEL -D SLG_OPENCL_KERNEL
[LuxCore][605.276] [MergeSampleBuffersOCL] Compiling kernels
[LuxCore][605.277] [MergeSampleBuffersOCL] Kernels cached
[LuxCore][605.277] [MergeSampleBuffersOCL] Compiling Film_MergeBufferInitialize Kernel
[LuxCore][605.277] [MergeSampleBuffersOCL] Compiling Film_MergeRADIANCE_PER_PIXEL_NORMALIZED Kernel
[LuxCore][605.277] [MergeSampleBuffersOCL] Compiling Film_MergeRADIANCE_PER_SCREEN_NORMALIZED Kernel
[LuxCore][605.277] [MergeSampleBuffersOCL] Compiling Film_MergeBufferFinalize Kernel
[b][LuxCore][605.277] [MergeSampleBuffersOCL] Kernels compilation time: 1ms[/b]
[LuxRays][605.816] [Device ATI Radeon HD 5750 Intersect] Accumulation buffer size: 175Kbytes
[LuxCore][605.816] [Reinhard02ToneMap] Defined symbols: -D LUXRAYS_OPENCL_KERNEL -D SLG_OPENCL_KERNEL
[LuxCore][605.817] [Reinhard02ToneMap] Compiling kernels
[LuxCore][605.817] [Reinhard02ToneMap] Kernels cached
[LuxCore][605.817] [Reinhard02ToneMap] Compiling OpRGBValuesReduce Kernel
[LuxCore][605.817] [Reinhard02ToneMap] Compiling OpRGBValueAccumulate Kernel
[LuxCore][605.817] [Reinhard02ToneMap] Compiling Reinhard02ToneMap_Apply Kernel
[b][LuxCore][605.817] [Reinhard02ToneMap] Kernels compilation time: 0ms[/b]
MacBook Air with M1
MacBook Air with M1
