OpenImageDenoise
Re: CGI tech news box
Post by epilectrolytics »
lacilaci wrote: Tue Jan 29, 2019 8:29 pm Well if we will have indirect and caustic caching you won't need bidir, would you? + this type of denoiser and rendertimes will be in minutes for complex scenes
The strength of Luxcore is its unique light balance, which is even better in Bidir than in Path.
PhotonGI is biased and what kind of light mood it will produce remains to be seen once it's finished.
I wonder what the cache sizes will be on complex scenes and if it all fits into GPU ram or what happens to render speed if it doesn't.
Also it is possible to use a photon cache for indirect light importance sampling in Bidir and Path (slower than direct lookup but unbiased with no splotches 8-) ).
There are lots of very interesting combinations possible...
Re: OpenImageDenoise
Another test.
Samples: 128
BCD denoising time: 53 seconds (default settings)
OIDN denosing time: 1.7 seconds (yes, less than 2 seconds)
noisy
noisy
BCD
BCD
OIDN
OIDN
And another one, this time with a 1000 samples image for comparison.
Noisy, 64 samples
Noisy, 64 samples
BCD
BCD
OIDN
OIDN
1000 samples
1000 samples
It should be "trivial" to integrate as another image pipeline plugin :idea:
Yes. The API looks a lot simpler than the one of BCD on first inspection.
B.Y.O.B. wrote: Tue Jan 29, 2019 11:22 pm Yes. The API looks a lot simpler than the one of BCD on first inspection.
Any taker ? :mrgreen:
alpistinho
Post by alpistinho »
Dade wrote: Tue Jan 29, 2019 11:24 pm
I will take a shot, even though I shouldn't :lol:
Post by lacilaci »
Dade wrote: Tue Jan 29, 2019 11:19 pm It should be "trivial" to integrate as another image pipeline plugin :idea:
needs albedo pass to maximize potential :!:
alpistinho
alpistinho wrote: Tue Jan 29, 2019 11:35 pm I will take a shot, even though I shouldn't :lol:
I have forked into https://github.com/Alpistinho/LuxCore.
Thanks to the tutorial in the wiki I have added a dummy implementation for the classes and got it compiling.
I hope I don't take too long to get it working
lacilaci wrote: Wed Jan 30, 2019 12:13 am needs albedo pass to maximize potential
I'm pretty sure we can add that.
alpistinho wrote: Wed Jan 30, 2019 12:51 am
Great! If you have any questions, we're happy to help.
