I wanted to test something and I'm getting an error that sample data buffer is too big for gpu.
Normally I would get this error when I'd try to render high res. image on opencl and have denoiser enabled, but now I get this error even in low res and denoiser disabled.
I don't know if it's a scene problem or bug so here's a test scene.
OpenCL+Metropolis won't render
- glass_interior_test_279.blend
- (2.06 MiB) Downloaded 148 times
Re: OpenCL+Metropolis won't render
Metropolis is a much more complex sampler than Sobol or Random, and on the GPU it consumes more memory (because there are more cores, and each core needs a copy of the sampler).
The scene probably fits barely in memory without it.
I was able to run metropolis on opencl in my "first steps" project at high resolutions. This is empty scene at 1200x1200.B.Y.O.B. wrote: Mon Jan 21, 2019 7:48 am Metropolis is a much more complex sampler than Sobol or Random, and on the GPU it consumes more memory (because there are more cores, and each core needs a copy of the sampler).
Oooooh sh!t...
I know... I've set too many diffuse and other paths so that why it fails on gpu. Didn't expect that to make problems
Metropolis needs to save a lot of information for each path vertices. GPUs are also running many hundred of thousands of threads for the rendering. The product of number of threads for max. path depth will determine the amount of ram required.lacilaci wrote: Mon Jan 21, 2019 6:47 am I don't know if it's a scene problem or bug so here's a test scene.
Your 100 max. depth setting requires a lot of ram. Just reduce the max. path depth (100 is really a huge number). The other option would be to reduce the number of threads (there is a parameter) but at the cost of some performance.
Yes yes, I understand now where was the problem. Thanks for explanation.
BTW. In this scene I realized I cannot get sunlight through 3 layers of thick glass panels unless I use bidir+metropolis. (I assume it's just too difficult)
This makes me wonder if cache could actually help even with something like this.
You'll have to set the glass to "architectural" so direct light can pass through.
Otherwise, all light passing the glass is caustics, and those are obviously very hard to render for unidirectional path.
I see... maybe the new caching could make this renderable though.B.Y.O.B. wrote: Mon Jan 21, 2019 12:45 pm You'll have to set the glass to "architectural" so direct light can pass through.
The problem with archglass is no refraction. Ideally there would be an option to make glass simply invisible for lights/shadows.
Maybe, but all the photons that shine through the glass will end up in the caustics cache and will probably still be harder to trace than direct/indirect photons.lacilaci wrote: Mon Jan 21, 2019 12:55 pm I see... maybe the new caching could make this renderable though.
For thin window glass (a few millimeters) this doesn't really make a difference.
See also https://wiki.luxcorerender.org/LuxCoreR ... hitectural
If you have a glass sheet without a frame, a trick to have the border visible is to use "real glass" only for the border, but architectural glass for the rest of the sheet.
- red = real glass, white = arch. glass
- 2019-01-21_14-23-25.png (8.44 KiB) Viewed 4703 times
hmm... Neat trick, thanks.B.Y.O.B. wrote: Mon Jan 21, 2019 1:17 pmMaybe, but all the photons that shine through the glass will end up in the caustics cache and will probably still be harder to trace than direct/indirect photons.lacilaci wrote: Mon Jan 21, 2019 12:55 pm I see... maybe the new caching could make this renderable though.For thin window glass (a few millimeters) this doesn't really make a difference.
I still hope to see some path/visibility options per object in future
