Bump node-Slider control
kullboys
Post by kullboys »
Hi
I'm finding that when there is a value of -.01 in the Bump node's Bump Height, then the slider control for that value stops working, and if a new value is required it has to be typed in.
Thanks.
Re: Bump node-Slider control
This is intentional.
You can change it in this file: https://github.com/LuxCoreRender/BlendL ... ump.py#L10
Racleborg
Post by Racleborg »
There's also some info here: viewtopic.php?f=4&t=676
careful, this is a scam!
The post is an exact copy of what racleborg quoted.
Note the hyperlink in the full stop behind the "Thanks"
Thanks for the heads up CodeHD, I banned kullboys.
Racleborg
Post by Racleborg »
I thought the query looked familiar! ;)
