In there a way to input vertex information to mix materials for LuxCore? In Cycles there is the Attribute node.
An example of usage: The Grove assigns vertex data when trees are created such as Shade, Thickness, Dead, etc. In Cycles I can create a single material that mixes different bark textures depending on the vertex information. (Trunk bark is different than branch bark. Dead branches have dead bark.) This makes it very quick and easy to add different textures for the entire tree.
Mixing Materials Using Vertex Colors or Vertex Groups
Re: Mixing Materials Using Vertex Colors or Vertex Groups
I see this question has come up before: http: viewtopic.php?t=610
The vertex color texture can be found in the add node menu: Add -> Texture -> Vertex Color (near the bottom of the list).
Vertex groups are not accessible in materials.
I don't see any way to assign a specific Vertex Color map in a Vertex Color node. Is it only possible to use one Vertex Color layer at a time?
Node setup below works...
..., but only for the active Vertex Color layer:
In Cycles it is possible to mix several Vertex Color layers in one material:
LuxCore only supports one vertex color layer per mesh.
You will have to make do with the three RGB channels.
However, multiple vertex color layers are logged as a feature request if I remember correctly.
Thank you for your responses B.Y.O.B. I suppose one using one vertex color layer is better than none at all!
I tried Luxrender a few years ago, but reverted back to Cycles. LuxCore seems to be so much more user friendly. Appreciate your work on it.
Quick additional question: Is there a way to make the background transparent in LuxCore?
Thanks, glad you like it.CEROE wrote: Fri Jan 11, 2019 7:37 pm I tried Luxrender a few years ago, but reverted back to Cycles. LuxCore seems to be so much more user friendly. Appreciate your work on it.
Yes, camera properties, imagepipeline panel. There's a checkbox called "Transparent" or so.CEROE wrote: Fri Jan 11, 2019 7:37 pm Quick additional question: Is there a way to make the background transparent in LuxCore?
"Transparent Film"
Got it, thank you!
Got it, thank you!
