Lamps
Re: Lamps
I also got some random crashes with Opencl GPU (only HD7970 no intel). but most of the time the rendering sucessfully start without crashes and without any change in settings after a blender restart.
Re: Lamps
I also have a HD 7970 on my Windows system and had crashes in the past, but since the last driver update I did (about 2-3 months ago) I have no crashes anymore.
Re: Lamps
With LuxCore 1.6 or 1.7, I had a few crashes but only when my LuxCore Output tmp folder need to be deleted or cleaned because
it was using to much memory for the hair particle grass.
I have my windows operation system, blender and all my files in the solid-state drive which is much smaller than my
hard drive. I have to make as switch and store much of my folders in to the hard-drive.
Re: Lamps
I tried different file called "GELAS_luxcorev2.blend" and also crashed when using GPU and PATH over here:
viewtopic.php?f=2&t=45
