That brick sticking out of the wall is child object, which is duplicated with parent object's option "Duplication - Faces".
Is it possible not to render that base object? I exclude layer with the brick from rendering, but it still casting shadow.
Duplicated objects
Re: Duplicated objects
Uh, this is very strange, can you post a test scene ?wasd wrote: Wed Dec 26, 2018 10:51 pm I exclude layer with the brick from rendering, but it still casting shadow.
- Attachments
- bricks-test.blend
- (640.54 KiB) Downloaded 181 times
Looks like a bug in the Blender addon.
I found that as a temporary workaround, you can hide the duplicator by disabling the render visibility (in the outliner).
Obviously this is not how it should work in Blender, it's a regression in the addon. I'll try to fix it.
Don't exclude the layer through render layers, this is a different functionality (it makes all objects on excluded layers invisible to the camera only).
