Really really nice and minimalistic Animation love it. What kind of PC do you have ?epilectrolytics wrote: Mon Oct 22, 2018 10:32 am New animation!
https://www.dropbox.com/s/2irt672yd0pgco9/moebius1.mov
Needs more samples but that has to wait till I got a faster PC.
playing with caustics
Re: Moebius
Re: playing with caustics
Thanks Charles.
I'm on a MacBook with with a quad-core i7 and a GT750M (see signature) which is not quite sufficient for animation rendering.
For Xmas I'm looking for something more adequate with a hexacore at the least.
Animated volumetric caustics!
Wanted to do this for years, now it took me three days to render four seconds
https://www.dropbox.com/s/nuvb4f6oakvuq6y/waves.mov
The render speed of the Ryzen octocore in my new PC is not as fast as I hoped for.
Maybe this is a Windows thing, like on Linux CPU rendering would be faster?
I think I read somewhere that rendering with Cycles on Win10 was slower than on Win7 or Linux.
And maybe the Spectre and Meltdown patches are slowing down things?
pool6.blend.zip- (114.92 KiB) Downloaded 1361 times
Cool!
I don't know if the same applies to LuxCore, someone should test it.
This is the case since years before Spectre/Meltdown were discovered.epilectrolytics wrote: Fri Dec 14, 2018 1:35 pm I think I read somewhere that rendering with Cycles on Win10 was slower than on Win7 or Linux.
I would be interrested in some proper comparison on the matter...B.Y.O.B. wrote: Fri Dec 14, 2018 1:39 pm Cool!This is the case since years before Spectre/Meltdown were discovered.epilectrolytics wrote: Fri Dec 14, 2018 1:35 pm I think I read somewhere that rendering with Cycles on Win10 was slower than on Win7 or Linux.
I run both windows 10 pro and ubuntu 18.10 and so far I haven't noticed any significant differences on either cycles or luxcore.
If there are any they're probably not too noticeable, what's slow is slow what's fast is fast on both systems (and that's with my win install running all kinds of services and malwarebytes and who knows what accumulated over years, while my linux is relatively fresh and clean of anything).
wich ryzen ? and how fast you expect it to be ? how fast are you on this ? : viewtopic.php?f=3&t=574&hilit=benchmarkThe render speed of the Ryzen octocore in my new PC is not as fast as I hoped for.
So i can compare to my i7 8700k for you.
Ryzen 2700X (see signature).
I was comparing it to the Intel quadcore i7 2.3GHz in my MacBook and on the pool scene I posted above the Ryzen does ~950k samples/s whereas the i7 makes ~440k (one frame takes 40 min on the Ryzen).
I was hoping a newer CPU with double thread count and more GHz would do better than 2.2x.
But Geekbench4 is 26642 vs 12226, so apparently I'm good
I posted a result there, 4min 17s but with GPU support.how fast are you on this ? : viewtopic.php?f=3&t=574&hilit=benchmark
I will do a CPU run later and report, thanks for your offer
That's helpful, I won't start experiments with Linux then, I'm new to Windows, had the guys at the PC shop assemble and install everything for me and am very happy that everything runs smoothly, so I can concentrate on learning Blender and LuxCore better instead of struggling with the operating systems.lacilaci wrote: Fri Dec 14, 2018 2:07 pm I run both windows 10 pro and ubuntu 18.10 and so far I haven't noticed any significant differences on either cycles or luxcore.
Note that this only concerns C++ CPU rendering, not OpenCL/CUDA.lacilaci wrote: Fri Dec 14, 2018 2:07 pm I run both windows 10 pro and ubuntu 18.10 and so far I haven't noticed any significant differences on either cycles or luxcore.
Hm, interesting.
I'll do some comparison once we get gi caching. No point rendering on cpu now.
Re: playing with caustics!
Actually it works quite well.epilectrolytics wrote: Fri Dec 14, 2018 1:35 pmThe render speed of the Ryzen octocore in my new PC is not as fast as I hoped for.
Apparently Intel CPUs with similar core and GHz specs have advantages in speed and power efficiency, but not equivalent to their price premium.
________
And now for an attempt with glossy and matte (straw and cloth) translucency:
(Bidir CPU as usual)
