Ok I did it.
This node is a monster...
It would be much nicer to have a generic "double sided material" which accepts two materials as inputs for front and back, like the mix material.
But I don't know if that's possible to do in the material sampling code in case of translucent materials or glass.
BlendLuxCore Development
Re: BlendLuxCore Development
Ok I did it.
Also i think viewport halt condition need more if condition. when i increase/decrease halt time during preview i get viewport RT restart. normally render should stop if i decrease and continue if i increase.
It works exactly like you say it should here, can't reproduce any restarts.Sharlybg wrote: Tue Jan 23, 2018 8:29 pm Also i think viewport halt condition need more if condition. when i increase/decrease halt time during preview i get viewport RT restart. normally render should stop if i decrease and continue if i increase.
Crappy video but you see what i'm telling :B.Y.O.B. wrote: Tue Jan 23, 2018 8:33 pmIt works exactly like you say it should here, can't reproduce any restarts.Sharlybg wrote: Tue Jan 23, 2018 8:29 pm Also i think viewport halt condition need more if condition. when i increase/decrease halt time during preview i get viewport RT restart. normally render should stop if i decrease and continue if i increase.
https://drive.google.com/open?id=1cL6sY ... o6S1dG4F6g
It continues if the rendering has not already be stooped, try to put 60secs, and than 90secs while the 60secs has not yet over. Continue after it has already been stopped would require to not stop the rendering but to put the rendering in pause so it can be resumed.Sharlybg wrote: Tue Jan 23, 2018 8:53 pm Crappy video but you see what i'm telling :
If it is stopped, it can not be continued because all the memory has already been freed, etc. (which is an advantage on its own).
The scene is put in pause if the halt time is reached. And it is resumed when the halt time is set to something greater than before.
Attached is a video how it looks on my end. I'm basically doing the samy things as you, Sharlybg, and it works like expected.
Hm...
Hm...
- Attachments
viewport.webm.zip- (3.35 MiB) Downloaded 447 times
I understand you. But the behaviour i want to describe is the one cycles do {""baaaah cycles **** you again"""}.In cycles if the render preview set to 32 and reach 32 and then the user enter a number lower than 32 (eg. 16) the preview will not be updated as there is no change to the scene.the stats will just return 32/16.B.Y.O.B. wrote: Tue Jan 23, 2018 9:04 pm The scene is put in pause if the halt time is reached. And it is resumed when the halt time is set to something greater than before.
Hm...
Cycles is kind of the reference implementation when it comes to the Blender RenderEngine API.
I have no problem comparing with it
I can not think of a reason why on my Linux everything works like it should and on your Windows it resets.
You can open an issue on github so I don't forget about it, but for now I think it's a minor issue and I won't try to debug it.
The next alpha version will contain a "fire and smoke" preset:
The next alpha version will have support for transparent film and shadow catcher:
