Such kind of work totally deserve all the need to come to life. do it 4k with as much as samples possible it is a masterpiece. just remenber my simple cold fusion scene (but in my case i should had use laser to drastically reduce the time instead of hiden light plane inside box.Racleborg wrote: Sun Nov 18, 2018 6:43 pm Well, it looks great! So if it takes a month, then it takes a month![]()
Different exposure when rendering different parts of the image
Re: Different exposure when rendering different parts of the image
Thanks guysSharlybg wrote: Sun Nov 18, 2018 10:56 pm Such kind of work totally deserve all the need to come to life. do it 4k with as much as samples possible it is a masterpiece.
I'll give it another month if I have to but I'd rather find out how Lux does gamma and fix my render if possible.
I'm afraid I haven't seen your cold fusion scene but I'd love to. Do you think there's anything I could do about my scene to speed it up without compromising quality?Sharlybg wrote: Sun Nov 18, 2018 10:56 pm just remenber my simple cold fusion scene (but in my case i should had use laser to drastically reduce the time instead of hiden light plane inside box.
Does anyone know how Lux does gamma? I mean, what's the maths? If it's just an exponent I must have done something wrong
Here: https://github.com/LuxCoreRender/LuxCor ... on.cpp#L45FXtend wrote: Wed Nov 21, 2018 3:06 pm Does anyone know how Lux does gamma? I mean, what's the maths? If it's just an exponent I must have done something wrong![]()
Did you render this in Blender or outside (using luxcoreconsole or luxcoreui)?
Because we don't use the gamma correction plugin in Blender, Blender does the gamma correction for us.
- FarbigeWelt
- Contact:
Does exr format support a kind of reset? I mean gamma, exposure and color space are rather a look up table for how the file has to be displayed and raw information is not touched.
Sorry to jump post, but how do you install these? I downloaded the standalone version, but can't see an .exe file in it.using luxcoreconsole or luxcoreui
Thanks
https://github.com/LuxCoreRender/LuxCor ... opencl.zip includes a luxcoreui.exe and pylucoretools.exeRacleborg wrote: Fri Nov 23, 2018 3:50 pmSorry to jump post, but how do you install these? I downloaded the standalone version, but can't see an .exe file in it.using luxcoreconsole or luxcoreui
luxcoreconsole is included only in the SDK version (as a demo with source) but "pylucoretools.exe console" does exactly the same task.
I did it in Blender. Thanks for the infoB.Y.O.B. wrote: Wed Nov 21, 2018 6:08 pm Did you render this in Blender or outside (using luxcoreconsole or luxcoreui)?
Should just be v^gamma or v^(1/gamma) where v is the value of the pixel, right? At least that's what the gamma node seems to do.
