Hi
I've sorted myself out with Dropbox, and here is a link to the file: https://1drv.ms/u/s!AhdwgLaw01tLjw9eOm3tpXFb4UZS
Everything has been taken out except the Mesh-Lights, Sun and camera.
If you need some meshes putting back; I can do that but it can gets quite large to upload.
Cheers
Max Brightness Value
Re: Max Brightness Value
Here too
I've only had the NAN once.
The scene I am working on is still very WIP and I'm adding more and more stuff to it, so there is a chance it will re-occur and as soon as it does I'll save a copy of it at that point for you. Unless of course there is anything else you would like me to do in the meantime?
Just let see if it happen again or not.Racleborg wrote: Fri Nov 16, 2018 9:35 am I've only had the NAN once.
It's just done it again. (Snip image attached).
If you could just bear with me whilst I upload the whole project as our broadband connection is rubbish!
The scene is not going to be very useful anyway if it is not something I can reproduce in a reasonable number of tries. When do you get the NaN value ? Soon after starting the rendering ? At some point during the rendering ?Racleborg wrote: Fri Nov 16, 2018 2:36 pm It's just done it again. (Snip image attached).
@B.Y.O.B.: at what point do you call the get film luminance method in BlendLuxCore ?
Soon after starting the renderingWhen do you get the NaN value ?
Sorry, I don't understand the question.@B.Y.O.B.: at what point do you call the get film luminance method in BlendLuxCore ?
Ok, I see, just opening the scene, shows a NaN value. @B.Y.O.B. is it an uninitialized variable ? Where does it come from as soon after having just opened the file ?
