DLCS and Round objects
Post by lacilaci »
There are artifacts over round objects that appear everytime I tried to use dlcs in any scene.
luxcoreDLCS.blend
(3.62 MiB) Downloaded 1187 times
Re: DLCS and Round objects
Post by lacilaci »
normal angle of 1 degree...
Maybe there should be some sort of retracing at the breaking angle, so that cache is not being used on the very edge..?
Post by lacilaci »
Also, is DLCS working with bi-dir?? Cause it shows being computed, however I don't see those artifacts on bidir, so I don't know
Such a scene is not well suited for DLCS. Basically, DLCS is applicable only in specific cases & scenes.
Understanding the fine line, then applying that knowledge, is what makes a fine artist.
Once in a while, a homework, is what everyone must do.
Post by lacilaci »
kintuX wrote: Thu Nov 01, 2018 8:34 pm Such a scene is not well suited for DLCS. Basically, DLCS is applicable only in specific cases & scenes.
Do you understand that this is a simplified scene to show an issue I'm having with dlcs?
Or do you plan to tell me on every issue I find that I should either fix it my self or learn to work around the issue, or simply stop using luxcore?
lacilaci wrote: Thu Nov 01, 2018 12:14 pm There are artifacts over round objects that appear everytime I tried to use dlcs in any scene.
The source of the first problem was in using the geometry normals instead of the shading one (so the result was faceted). I fixed this problem:
The second problem was in the condition for merging the information of neighbors cache entries. It was too strict and causing problem on edges with normal interpolation. I fixed this problem too and now the rendering looks fine:
You can use daily build to test the fixes, it should be ready in a couple of hours.
Post by lacilaci »
Dade wrote: Fri Nov 02, 2018 11:03 am
Fantastic, looks flawless now.
lacilaci wrote: Thu Nov 01, 2018 12:29 pm Also, is DLCS working with bi-dir?? Cause it shows being computed, however I don't see those artifacts on bidir, so I don't know
BiDir can not use DLSC because it is not applicable there: BiDir emits particles starting from light sources without knowing where they land (and the cache entries are on object surfaces). BiDir has also many ways to transport light so a direct light sampling only acceleration would have far smaller impact on the noise.
Note: from a "syntactic" (LuxCore API) point of view, you can use DLSC with BiDir but DLSC, in this case, will just fall back to normal LOG_POWER light strategy.
Post by lacilaci »
Dade wrote: Fri Nov 02, 2018 11:11 am
But it's still being computed if selected, Maybe it should be disabled as an option in blender addon?
TOTAL TRUTH : my own test 120 sc render each
